Clutch Slave Ring Dimensions?
Anyone happen to have a loose clutch slave cylinder (S1) and a pair of calipers handy that could measure:
1. The outside diameter of the cylinder itself
2. The diameter of the snap ring groove
3. The width of the snap ring groove
Getting ready to tear into it again, and tired of messing around with the standard snap ring. Even with the right tool, I always yield the material and then have a heck of a time getting it to secure properly.
Going to get with some spiral and snap ring companies my employer works with and see what I can come up with.
Thanks!
Thanks!
Scott In Ohio
26/3795
26/3795
- 65 Lotus
some info at this post
elan-plus-f13/clutch-slave-retaining-clip-t17341.html
some more here
elan-f15/clutch-slave-clip-question-t14672.html
searched on slave C clip
http://www.lotuselan.net/cgi-bin/search ... oom_sort=0
Looks like .064 or .065 inch
looks like 1 inch id and 1.180 or 1 and 3/16 od maybe a little less as its a used clip and it may have stretched some.
links
http://www.rotorclip.com/products.php
http://www.ring-masters.net/
thanks Russ for the links
Gary
some more here
links
Gary
spare cylinder for my S4 and I believe they are all the same measures
snap ring groove width 2.10 mm
snap ring groove base diameter 26.25 mm
cylinder OD 28.25 mm
tolerances of about +/- .05 mm on these measurements due to wear or out of round
