5 Speed Clutch Plate
PostPost by: bcmc33 » Sun Aug 16, 2009 10:04 pm
I?m in the process of preparing to install a Lotus 5 speed box as a winter project.
I bought an 8.5? clutch plate at a parts fair some time ago, but now realise that it has 7/8? x 20 spline which is no good for the 5 speed.
The 5 speed is 1.11? x 25 spline which I don?t think is a Ford spec. Does anyone know what standard production clutch plate was used?
Also while on the subject, are there any other things I need to know regarding the fitment of the 5 speed to the Twnik?
I seem to remember an old thread that said something about the pilot bearing, but can't find it in the archive.
Brian Clarke
(1972 Sprint 5 EFI)
bcmc33
PostPost by: john.p.clegg » Mon Aug 17, 2009 5:40 am
Brian(friend)
Not 100% about this but maybe HB 2615 from an Elite + Eclat 5 speed 521 with a mod of machining 5mm off the flywheel side of the hub if necessary...
John :wink:
PostPost by: stuartgb100 » Mon Aug 17, 2009 6:04 am
Brian,
COVER PLATE: DELPHI BORG & BECK HE2848 Paul Matty
DRIVEN PLATE: PRECISION PARTS 7.Q 2615 or 7.0 2615 ? ditto
RELEASE BEARING FBJ EQ3259241 Rwf PN 0531384 ditto
Best to double check these references, but it's what my records show.
Stuart.
stuartgb100
PostPost by: AussieJohn » Mon Aug 17, 2009 7:28 pm
The gear lever comes out in a slightly different position; the exhaust manifolds are different part numbers on a 5 speed to a 4 speed; maybe a clearance problem at the gearbox; nothing that can't be sorted, good luck, John.
AussieJohn
