Clutch Part Numbers
I have a new unused clutch cover that I bought years ago when I used to run a Mk2 Lotus Cortina. The cover is numbered HE2842, and from memory I think this was listed as a heavy duty clutch for the L/C. I would obviously like to use it on my S4 but I am unable to find any references to this number. Could someone help with confirming that this cover is OK for Elan use and also I would like the part numbers of the correct plate and bearing to match.
- smo17003
The data I have in a listing I'm putting together is as follows
Clutch plate & Pressure plate = AP 47625/209
Clutch Trust Bearing = Ford 105E7580-B, JC Whitney 89-4134,
SKF 307500 For the 4 speed box
Clutch Trust Bearing = Ford 3014E7548-C SKF 413708 Fafnir CT5540 for the 5 speed box
Hope this help
Hope this help
Peter Mallinson
[email protected]
[email protected]
pmallinson - Second Gear
Borg & Beck catalogue says: HE2842 - Escort RS1600 73-74, Escort t/c
68-71, Lotus cortina 67-70. jc
- john-c-elan+2
smo17003 wrote:I have a new unused clutch cover that I bought years ago when I used to run a Mk2 Lotus Cortina. The cover is numbered HE2842,
I also have a HE2842 pressure plate, it does not have the plate attached to the diaphram fingers and to use it in a 4sp Elan you would have to change the release bearing from the flat faced type to the rounded face type.
Mine is also listed for use with a Twin Cam Escort.
types26/36/74 wrote:smo17003 wrote:I have a new unused clutch cover that I bought years ago when I used to run a Mk2 Lotus Cortina. The cover is numbered HE2842,
Brian,
Any chance of the corresponding part numbers for the driven plate and the bearing?
- smo17003
smo17003 wrote:smo17003 wrote:]
I fitted one including friction plate and rounded release bearing to my S2 (4sp) several years ago and to the best of my knowlege it is just the 5sp set up ........8.5" friction plate as opposed to 8" plate.
I cannot remember if I had to change or modify the release bearing carrier or not. Sorry I dont have the part numbers but I'm sure "john-c-elan+2" has got them ?????.........John?
