Clutch MC seal gets stuck
PostPost by: The Veg » Sun Nov 24, 2019 3:16 pm
Copper did the trick after annealing them at the MC, but NOT at the SC, which has plenty of flat surface for anything to seal against.
2012 BMW R1200GS
The Veg
PostPost by: The Veg » Sat Nov 30, 2019 12:04 am
OK, latest update. I don't think I ever clarified this, but the banjos in question are not on the same hose, not that that detail really matters. The one from the MC to the SC has a banjo up at the MC connection and a 3ANF followed by a 3AN-to-3AN nipple and an aluminium washer at the SC end. This setup was supplied by one of the Usual Suspects (DBE I think) to replace a failed red hose, and the end with all the 3AN stuff has yet to leak. The banjo at the SC is on the hose that goes to the remote-bleed, installed because I don't fancy the idea of having to lift the car and remove the heat shield I made just to bleed the clutch. This is the banjo that has continued to leak no matter what I've tried.
At last count, there were two possibilities: some issue with the banjo or some issue with the SC. Today I tried to figure out which by swapping which connection was in which hole. The result was as clear as daylight: the problem is with the banjo connection. It continued to leak while the 3AN held. One thing I noted was that the 3AN nipple had a MUCH wider surface with which to bear on a washer.
2012 BMW R1200GS
The Veg
Previous
