Elan S4 clutch
Operating the cylinder with pedal and brake line disconnected will help isolate whether you do or don't have a master cylinder problem
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
lotusposition wrote:Thanks Roger,
That's about the same size as my original pushrod. Unfortunately I was finding gear changes rather notchy when clutch was adjusted correctly as per the workshop manual.
I found Brian's measurement and drawing very misleading which led me to fitting an adjustable rod several mm longer than your own measurement.
Based off of the new information about a notchy gearchange from your other topic, I'd investigate whether the slave pushrod is adjusted correctly and change the master pushrod back to the original one.
Scott
45/9011
Hawkestone, On, Ca
45/9011
Hawkestone, On, Ca
- snowyelan
