master or slave clutch cylinder?
PostPost by: patrics » Fri Aug 31, 2018 8:45 pm
Bleeding the clutch is an easy task if done with some thought - but to make life easy you need to run aeroquip from master to slave,
Anyway how to bleed:
Bleed system with a couple of pumps - make sure slave piston is pushed back in to bore.
remove slave and hold level or there about with master cylinder - so fluid is in equilibrium
Remove bleed screw completely
Tip brake fluid gently down bleed screw port - obviously slave should be clean of shit
Tap sides of cylinder and keep repeating
Replace bleed screw
Now system is 100% bled
Spent next to nothing on fluid and bled
patrics
Previous
cron
