clutch problem! HELP!!!
Thanks for the advice guys!
I shall strip the box this weekend and let you know what I find!
- gazzamuffin
Seems like a little contradiction here, you say the input shaft is locked but you can select all the gears and see the gears turning if you turn the output shaft.
Thats not possible, if the output shaft turns and the input is locked then it is never in a gear. The forward gears are all constant mesh so if you can see them turning and the layshaft is turning then the input shaft cannot be meshed with the layshaft
maybe the reverse gear set is jammed with the input ?
good luck
rod
good luck
rod
rodlittle - Third Gear
hi all,
just to give you an update regarding the gearbox, i decided to take the engine back out and strip the gearbox and replace the bearings.
when stripped, i couldnt find anything obvious however the bearings were replaces anyway.
when re-assesmbled the box is working fine!
thanks for all you help and comments!
I have another question now!
so I shall post that seperately!
thanks again!
thanks again!
- gazzamuffin
