Are Plus2 and S3 Elan window frames the same dimensions?
I have an S3 Elan and I've fitted new silent channel rubber along with new felt strips, but...
The new felt strips, as supplied, were too long for the window frame and had to have about 5 1/2 inches (~14cm) cut off of them to fit.
Also, the new silent channel rubber window run is very, very tight and pinches the glass so much that the motor has a hard time raising the window and squeals like a banshee!
I've tried liberal amounts of silicon lube which helped some, but the widow still is very hard to raise.
I was wondering if there was a difference between Plus2 and 'Baby' Elans with respect to their window frames.
Is it possible that I was sent Plus2 components instead of S3 style rubbers etc?
Paul Carew
Austin,Texas,USA
1967 Lotus Elan S3SE Right Hand Drive, FHC 36/7152 BOO 758F
Austin,Texas,USA
pcarew - Second Gear
I would guess that the window channels are stocked to whatever length will cover all models, then are cut to fit the actual use.
And, no the s3 and the +2 models are not the same.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
