Is this chassis bent? Forum wisdom required!
PostPost by: berni29 » Tue Oct 26, 2021 5:38 pm
Hi There
I am soon to take delivery of my early +2. It used to be raced a fair bit by the PO and has had a new nose section before being painted about 5 years ago. The repair was done by someone who used to do fibreglassing on the original production lines. So the PO says. I don't see any reason to doubt him.
While the body was off the car the PO welded the chassis and added strengthening plates etc. He also made some other modifications such as uprated suspension mountings at the front.
However....... If you look in the engine bay, you can see there is a hole (made by the PO) where the top of the front damper can be seen peeping through. This must mean that the chassis in that corner is bent yes? All of the other mounting holes line up and everything else looks great.
What do we think? I have bought the car and have allowed for a chassis change (well, the cost of a good secondhand replacement chassis), I don't count the labour as it will be fun.
Opinions as to the state of play here invited. The welding to the front turrets was pretty extensive and could have caused movement, as could the previous damage if it was not straight when welded.
Unfortunately I do not have a photo of the chassis on the side that has the problem.
Thank you in advance..... Berni
P1050437.JPG and
P1050428.JPG and
berni29
PostPost by: ill_will » Tue Oct 18, 2022 6:24 pm
Hi Berni
I assume the rubber bush at the corner is ok and hasn't collapsed in some way allowing the damper to stick through more than it should?
ill_will
PostPost by: berni29 » Tue Oct 18, 2022 6:36 pm
ill_will wrote:Hi Berni
I like your thinking but sadly not. I have the chassis off the car, and indeed the LHS turret is canted in a few deg. I now have an early but unused spyder spaceframe to go on.
All the best
Berni
berni29
PostPost by: Foxie » Wed Oct 19, 2022 11:31 pm
You might be interested in the tower brace I fitted.
IMG_0981.JPG and
IMG_0976.JPG and
68 Elan +2, 70 Elan +2s
PostPost by: alan.barker » Thu Oct 20, 2022 12:50 pm
Imho if you need a Tower Brace the Chassis/Subframe has seen better days.
PostPost by: rgh0 » Thu Oct 20, 2022 2:31 pm
On my Elan i have one side front shock top bolt that sticks through the body hole above it and the other side does not. On the Elan there were holes originally in the body. I know my chassis is straight but the body clearly is not so dont assume its a chassis problem versus a body problem.
PostPost by: alan.barker » Thu Oct 20, 2022 2:46 pm
+1 Rohan 100%.
I also have 2 TVRs and when you measure things on one side and compare to the other side the grp is assymetric
PostPost by: RichardHawkins » Thu Oct 20, 2022 6:30 pm
My body changed shape quite substantially after painting, which I suspect was caused by the paint being cured in an oven.
Richard Hawkins
RichardHawkins
PostPost by: Foxie » Thu Oct 20, 2022 8:05 pm
alan.barker wrote:Imho if you need a Tower Brace the Chassis/Subframe has seen better days.
It's on a new Spyder chassis.
The original Lotus tower cracked across. IMHO a design fault.
Live and learn !
P7030028.jpg and
FrontTowerA.jpg and
PostPost by: snowyelan » Thu Oct 20, 2022 11:20 pm
Quite the interesting failure. Did both sides (front and back on the RHS that is) crack the same way? I have seen corrosion erode the lower portion but not this before.
Scott
45/9011
Hawkestone, On, Ca
snowyelan
PostPost by: Foxie » Fri Oct 21, 2022 11:16 am
snowyelan wrote:Quite the interesting failure. Did both sides (front and back on the RHS that is) crack the same way? I have seen corrosion erode the lower portion but not this before.
The crack had travelled from the front to half way across the inner face. The chassis was repaired (the rear "ears" were also badly bent ) and used for another 11 years, before the Spyder chassis was fitted 24 years ago.
It's been hanging on the garage wall ever since.
RTower1.jpg and
RTower3.jpg and
PostPost by: alan.barker » Fri Oct 21, 2022 12:07 pm
Looks to me someone had ajustable Shocks and set them on hard. Or at the back if it is a +2 carried Adults which is far tooo heavy.
Our Elans are very delicate. Designed for soft long suspension and a pleasure to drive. Not karts, turn and squirt with blurred vision.
PostPost by: Foxie » Sat Oct 22, 2022 11:29 am
alan.barker wrote:Looks to me someone had ajustable Shocks and set them on hard. Or at the back if it is a +2 carried Adults which is far tooo heavy.
The facts are, at the time, the car only ever had the original soft long travel shocks as fitted at Lotus.
Adults were carried ? Was the Plus 2 not built, marketed and sold with 4 seats ? However, this car seldom carried any more than the driver.
It would be completely agreed that Elans are very delicate. There is a very good reason why Spyder have been doing nice business for well over 30 years !
Finally, I'll leave the last word to Mario Andretti:
When we first got together, Colin said "Mario, I always want to make a car as light as possible" I said, "Well Colin, I want to live as long as possible. I guess we need to talk"
RTower1.jpg and
PostPost by: Foxie » Sun Oct 23, 2022 10:29 pm
To be fair, I should advise that before I bought this car out of a scrapyard in Limerick in 1985, it had been driven for a number of years on the pot-holed bog roads of County Clare in the West of Ireland, where the second owner had retired to from the Manchester area . Definitely not fragile Lotus Elan country.
PostPost by: berni29 » Mon Oct 24, 2022 5:10 pm
Foxie wrote:You might be interested in the tower brace I fitted.
That is very interesting, and on the face of it an attractive idea, but I am not sure that on a chassis such as ours it might not just transfer any flexing along the line so to speak. Having said that I know people strengthen the tower uprights by welding in gussets. In fact my chassis has had that done. Sadly it has locked the upright at an incorrect angle.
All the best
Berni
berni29
Next
