Galvanised Chassis
PostPost by: jkatthehelm » Fri May 29, 2020 4:37 pm
Hi all
Are galvanised chassis currently available for the Plus 2?
Thanks!
James
66 Elan fhc, 72 Elan Plus 2S 130/5, 98 Elise 2.0l Duratec
_____________________________________
Which way up should this be???
jkatthehelm
PostPost by: MarkDa » Sat May 30, 2020 7:00 am
There's one for sale in Greece on Ebay.
Delivery may be an issue :D
MarkDa
PostPost by: alan.barker » Sat May 30, 2020 9:21 am
what i did for a friend a few years ago was put a wanted Advert in the Club Lotus Mag. For second hand or new galvanised Chassis and found one. I know it's all been said about galvanising distorting a Chassis BUT are the non galvanised that straight. All the adjustable "A" Frames are not just for cars with galvanised Chassis,
many are for cars with NON galvanised Chassis :shock: :shock:
Try a wanted Advert, it's free to Club Members and can save a lot of money to buy others things.
e.g. adjustable "A" Frames :wink: :wink:
PostPost by: tvacc » Sat May 30, 2020 4:46 pm
Now I don't know if it is still an issue, but I bought a galvanized frame for my Elan Sprint back in 1990 or so. It did warp, twisting it in the back. I had to put on adjustable spring perches to fix the ride height. I do not know if this is still an issue with galvanized frames. Going forward I do not know if I would buy a galvanized frame again.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham (Bought new), 05 Elise RD (Bought new),
99 Elise190, 05 Elise BLK (Bought nearly new), 2024 Emira, 2005 MiataSpeed Turbo
tvacc
PostPost by: alan.barker » Sat May 30, 2020 5:07 pm
Miles Wilkins fitted a Lotus Galvanise Chassis on my Sprint in 1985 and he didn't say it was warped. Also he didn't fit adjustable perches.
How accurate are NON galvanised Chassis, has anybody measure one.
Surely if a bare Chassis is warped it could be tweaked back into shape. or enough for adjustable "A" Frames to be fitted for the final tuning :wink:
PostPost by: tvacc » Sat May 30, 2020 5:47 pm
My chassis was fine for about 5 years. Then I started to notice that the distance between the bottom of the rear wheel well arch to the top of the tire was different from side to side. First it was one finger difference, then two, then 3. It was gradual. I did not know what was happening. It was years later after I sold the car that someone mentioned that this was a problem with galvanized chassis cars. I realized then that my car had the issue. Like i said, I fixed it with adjustable spring perches.
Tony Vaccaro
tvacc
PostPost by: alan.barker » Sat May 30, 2020 7:33 pm
Are you sure it was the Chassis moving and not the Body because it was not Shimmed correct to Chassis.
Difficult to prove unless Car set up on checking Jig. Chassis checked with reference points and then the Body to see if it is square on Chassis.
I know on TVR Cars the Body can be different each side and i think Lotus can have the same problem.
PostPost by: tvacc » Sat May 30, 2020 7:44 pm
Nothing is for certain. All I can tell you is that it always looked like the body was square on the chassis.
I no longer have the car so I cannot check.
Tony Vaccaro
tvacc
PostPost by: miked » Sat May 30, 2020 8:05 pm
I rejected two new chassis's in about 2001 since they were both wider between the left turrets than the right. By around 1/2 inch. Feedback was not appreciated. That being an understatement. For that car i had to use a Spyder chassis. The galvanised process had nothing to do with this. The jig was the culprit. Apparently a known fault as Spyder told me before I even opened my mouth. Not a happy bunny at the time. Since then i have experienced about 3 NOS ones from the late 80's and the 90's that were good on the tape.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked
PostPost by: alan.barker » Sun May 31, 2020 4:27 am
The problem could be one of the rear springs sagging .
PostPost by: elanfan1 » Sun May 31, 2020 4:59 am
It would be interesting to get a cost of having a new chassis shot blasted and Hot zinc wire sprayed - a common enough practise in shotblasting businesses. I’d anticipate a few hundred quid but could be spectacularly out. Effectively galvanising without the heat from dipping.
PostPost by: alan.barker » Sun May 31, 2020 5:40 am
Thank sounds good.
I am ćonvinced the best is galvanised.
When i look at the galvanised Watering Can that's been kicking around in my garden for 40 years and is still perfect. Plus galvanised Chassis fitted to my Sprint in 1985 still perfect.
I also think to paint over galvanised is a total waste of time and it will only peel off.
PostPost by: alanr » Sun May 31, 2020 8:24 am
Ok..So just supposing I was in the market for a new chassis at £2k+ for a bare untreated chassis. On collection I then measure it and decide it is within acceptable tolerances. Would I really want to risk then having it galvanised in which the heating process involved in galvansing could potentially ruin it? Personally I don't think I would want to take that risk!
With the annual mileage that most Elans and +2's now do and potentially will do in the future a painted chassis is going to last 25+years anyway so I don't see the point of taking the risk of having a chassis galvanised.
None of the curent suppliers it seems now recommend having a chassis galvanised because of the risk of distortion.
Alan.
Currently:-
1971 +2 S130/ 5speed Type 9.
PostPost by: nmauduit » Sun May 31, 2020 8:38 am
alan.barker wrote:I also think to paint over galvanised is a total waste of time and it will only peel off.
I respectfully disagree on this one: the ways to succesfully paint galvanized steel was discussed here before, from memory one needs to take in account the resting time since the galvanization process.
I prefer to paint a galvanized chassis for a more original aspect.
S4SE 36/8198
PostPost by: alan.barker » Sun May 31, 2020 8:49 am
Hi alanr,
as you like it's a personal choice.
It's a bit like when i talk about comparing TVR and Lotus. Many Lotus owners consider TVR as no good or visa versa.
I must say it's nice to know of the different possabilites .
Next
