Hood frame joining studs
PostPost by: s28ven » Mon May 11, 2020 2:21 pm
I have an original S3 hood frame although a few of the jointing rivets between the rails have failed.
Does anyone know the correct name of these fixings and possibly the size?
Steven
s28ven
PostPost by: ericbushby » Mon May 11, 2020 3:26 pm
Hi Steven,
I doubt that you will be able to buy these rivets, but maybe.
I have a similar hood frame with two missing rivets where it folds. I admit that they have a screw and nut in there just now.
I will repair it correctly some day, but the frame will have to come off to do it.
If you find a soft iron nail the correct diameter, then one end is already roughly shaped. When cut to the correct length the other end can be peined over into a rivet head using a small ball pein hammer on some sort of anvil, maybe the top of a vice. A small hammer is necessary to keep the distortion of the iron localised and under control.
That is the way I intend to do it.
Best of luck
Eric in Burnley
S3SE DHC
