door window frames sprint (the devils in the detail)
PostPost by: bloodknock » Sun Dec 29, 2019 8:16 pm
inside-door-top-edge-packing-piece.jpg and
Hi peeps,
I'm on the last lap, 100 yards out, and I've lost this part!
I believe its to supress vibration, it looks like hardboard, is it? I can see its length, BUT how thick is it?
Bob
PostPost by: gjz30075 » Sun Dec 29, 2019 8:47 pm
Hard to tell in the picture but it looks like the remnants of the window fuzzies. Two are required for each
frame. They cushion the glass to prevent rattles.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: bloodknock » Mon Dec 30, 2019 9:47 am
Thanks for your reply Greg.
Both doors have the window fuzzy strips fitted correctly.
These are photos as I stripped the door frames. I have misplaced the fiberous ?spacers?
These were glued to the door frame, attached to the inner edge of the top of the door frame
door-frames-as-removed.jpg and
spacer-block-inner-top.jpg and
Bob
PostPost by: Craven » Mon Dec 30, 2019 11:52 am
It may have been used to ensure the ?fuzzy? window wipe/seal is in contact with the glass.
Frame has no support in this area and it tends to bow away from the glass. I fitted thin rubber foam, a sort of self-adjusting pressure point between the frame and door.
FWIW
PostPost by: nigelrbfurness » Tue Dec 31, 2019 10:34 am
I use 3mm-4mm self-adhesive window felt for this. I use a lot of it in other restoration work too. It is quite firm but compressible. You can get it in reels on Amazon.
Last edited by nigelrbfurness on Wed Jan 01, 2020 9:58 am, edited 1 time in total.
nigelrbfurness
PostPost by: bloodknock » Tue Dec 31, 2019 10:55 am
Great, thanks Nigel, i'm on to it.
Bob
