Factory correct Frame color on the elan??
As I go thru pictures of restorations and elans on the internet and even this site, I see frames of several colors from black to red and that primer orange-ish color to silver or grey...?.So what is the "factory correct" frame color that the elan would have left the factory with? Is there one or did it change throughout the series? Thanks for any help on the subject
- Oasis1
I believe the early Cars [S1/2/3) were red oxide but some time around the S4 the red oxide then had black paint over it as well.
Not sure exactly when the Black was applied but most original Sprints I have seen seem to have had the black on top of the red oxide.
Brian wrote 'Not sure exactly when the Black was applied but most original Sprints I have seen seem to have had the black on top of the red oxide'
Hmm, not sure about that Mr G. Many of the original Sprints that I have owned seemed to have missed the red oxide booth, and were just blown over with black paint, which is why some chassis' lasted barely 3 years, so was a very hit or miss affair back in the day.
Leslie
Leslie
- 512BB
My original 1968 S4 chassis was just painted black. No sign of any red oxide under the black when I removed it around 1980 which was the first time it had ever come off the body.
I think the standard factory colour is rust red / brown
512BB wrote:'
Hmm, not sure about that Mr G. Many of the original Sprints that I have owned seemed to have missed the red oxide booth, and were just blown over with black paint, which is why some chassis' lasted barely 3 years, so was a very hit or miss affair back in the day.Leslie
Ah yes Leslie, that's because you only buy those cheap knackered old Sprints
may be one day you'll make me a decent offer for mine which btw the body has never been off its original chassis.
Attached a pic of where the black has come off the chassis .........and still NO RUST
I just redid my '69 S4 and the not-rusty chassis was red with a tar-like coating over it on the backbone part. I washed the black (which I thought had been added later in a poor attempt at undercoating) off with turpentine. The cleaned chassis could be blasted more easily. I had it repainted a similar red. The exposed parts of the frame were clean of black, the only rust was on the bottom horizontal part of the backbone near the rear.
We are supposed to be having fun, are we not?
- USA64
I dont know if anyone else has been following "restoration impossible" in Classic Motorsports magazine (and on the web). It is the complete restoration of an elan yanked from a field and broken essentially in two! The goal was to present a concourse elan from a car who everyone said was done and only a parts car (and not many of those!). It is a great story and has several detailed "chapters" on line. The frame in that restoration was sprayed with a rust encapsulator sold in cans on Eastwoods website. It looks great in the pictures on line. Would a sprint have been covered in the same color or black? Let me know what you think. I am trying to figure out what color to paint my frame ! Google.... restoration impossible classic motorsports....its worth the read. Thanks Jim
- Oasis1
Oasis1 wrote:Would a sprint have been covered in the same color or black? Thanks Jim
See above posts.
This is how I have treated my new chassis:
2 coats of Por-15 & 2 Coats of Por-15 Red Oxide topcoat as Por-15 is not UV proof...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
I don?t think much sunlight will get at it when fitted
Painted my stripped Caterham chassis in POR15 system (with no UV protection top coat) 8 years ago and still hard and black.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
The chassis on my 1968 Elan was red oxide primer when I bought it in 1979. I bought a Lotus replacement chassis, also in 1979, and this was painted black. The paint was so poorly applied, that it fell off before I used the chassis.
Richard Hawkins
Richard Hawkins
- RichardHawkins
This is way off the target, but it applies. About 40 years ago, I constructed a gate to cross my driveway, made of 1 3/8" galvanized fence tubing. I TIG'd the corners and painted them with an aluminum paint to keep them from rusting. Well, today, I am extending the gate to cover the now required 16' drive by the local government. What floored me was that that aluminum paint that I painted the welds, is not only still there, but none of the welds have rusted, and it is still sticking to the galvanized pipe. I actually found the little half pint tin of paint from years back, part of my hoarder personality, and it is still good. So, I painted the new welds that extended the gate an additional 3', and if they live for another 40 years, out in the weather 7/24/365, I will be a happy camper. I think if I were going to paint a chassis, I would do my best to try to find this aluminum paint, which probably no longer meets any sort of environmental requirements, which I bought at some now defunct home improvement store, Builders Emporium I think. The worst part is, there is no manufacturer listed on the tin. It probably causes blindness in cockroaches, and causes weight gain in termites, or something like that. But will prevent rusting in Lotus chassis that do not have oil leaks.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
prezoom wrote:This is way off the target, but it applies. About 40 years ago, I constructed a gate to cross my driveway, made of 1 3/8" galvanized fence tubing. I TIG'd the corners and painted them with an aluminum paint to keep them from rusting. Well, today, I am extending the gate to cover the now required 16' drive by the local government. What floored me was that that aluminum paint that I painted the welds, is not only still there, but none of the welds have rusted, and it is still sticking to the galvanized pipe. I actually found the little half pint tin of paint from years back, part of my hoarder personality, and it is still good. So, I painted the new welds that extended the gate an additional 3', and if they live for another 40 years, out in the weather 7/24/365, I will be a happy camper. I think if I were going to paint a chassis, I would do my best to try to find this aluminum paint, which probably no longer meets any sort of environmental requirements, which I bought at some now defunct home improvement store, Builders Emporium I think. The worst part is, there is no manufacturer listed on the tin. It probably causes blindness in cockroaches, and causes weight gain in termites, or something like that. But will prevent rusting in Lotus chassis that do not have oil leaks.
Possibly a zinc chromate primer. Good stuff, but may have chrome6 (hexavalent chromium).
Dan
I am sorry, but I don't understand... "Lotus that do not have oil leaks..."
Can you please explain?
1963 Unicorn
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
- knockoffnut
