Elan S3 chassis on an S4 Elan Body
PostPost by: loueelotus » Wed May 10, 2017 2:41 am
Quick question: I was wondering if a series 1,2,3 chassis will fit a Series 4 Elan shell?
Lou
Louis Lottner
Elan S2 1965 #26-4840
Colin Chapman’s immortal words ‘Simplify, then add lightness’
loueelotus
PostPost by: pharriso » Wed May 10, 2017 2:53 am
yes, there is only 1 chassis... fits all series
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: rgh0 » Wed May 10, 2017 11:25 am
The later S4 chassis (which is all that is supplied new these days) fits all bodies from S1. The key dimensional difference in the later chassis is a increased negative camber angle on the front suspension to suit the change to radial tyres.
Similarly an original early chassis will fit an S4 body shell but you will end up with a slightly positive front camber at standard ride height if its a truly original chassis.
Not sure when the change in front camber occurred but it was during the S3 run.
PostPost by: Spyder fan » Wed May 10, 2017 6:14 pm
Here's a chassis being polished at Spyder today!
2017-05-10-11.22.56.jpg and
Fits all versions
Note the square vacuum tank, previously used to be tubular for Spyder folded metal chassis, nothing to do with patent or copyright, just easier to make. Now customers demand originality, so Spyder make the folded metal chassis with 2 pack paint low baked, guaranteed 8 years for corrosion, mines lasted 10 years and still looks new
Kindest regards
Alan Thomas
Spyder fan
PostPost by: elj221c » Sat May 13, 2017 9:46 am
rgh0 wrote:The later S4 chassis (which is all that is supplied new these days) fits all bodies from S1. The key dimensional difference in the later chassis is a increased negative camber angle on the front suspension to suit the change to radial tyres.
Rohan, wasn't it caster/castor rather than camber?
Roy
'65 S2
elj221c
Users browsing this forum: Donels and 11 guests
