Towing Eye
After a chat with Dave about the difficulties of winching a car onto a recovery truck decided to get down and dirty before it gets too cold,so here goes...
A piece of stainless lying around...
and a length of 1/4 tool steel...
attacked with the welder...
a bit of a clean..
bolt it on
Hope I never have to use it...
a bit of a clean..
bolt it on
P.S.
The front being taken care of by a few feet of nylon rope round the plenum,held in place out of the way by a cable tie...one yank and it's down as my Grandmother used to say.
I think she was referring to those who were
Over-here,over-paid and over-sexed...
Ned
Bolted on the two unf bolts through the chassis into the boot ( battery earths).
I take your point but as you can see I've welded and gusseted the rack mounting legs and for strapping the car down on the trailer I'm sure it will suffice. You will also see I've only used a single mounting bolt to avoid straining the leg. I guess I could do a quick FEA to check it out but when you've done and said all its only a tie down.
- 65ginetta
..and as for the rope,when it's unravelled it's pulling on the plenum not so much the steering rack platform.
65ginetta wrote:I take your point but as you can see I've welded and gusseted the rack mounting legs and for strapping the car down on the trailer I'm sure it will suffice. You will also see I've only used a single mounting bolt to avoid straining the leg. I guess I could do a quick FEA to check it out but when you've done and said all its only a tie down.
for strapping down to a trailer i use 4 webbing straps threaded through a hole in each wheel.
- alan.barker
Have you cling-filmed it or has it been that long on the trailer that spiders have cocooned it....
hi John,
there was no Windscreen or back Window when i picked up the car and the Weather Forecast was rain.
I had 900 kms to drive back to France so i wrapped it using a big industrial roll of cling film.
I can recommend this it works very well. When i arrived back in Brittany the TVR 1600M was very clean after a shower for 900 kms
- alan.barker
When working on the exhaust I decided to weld 2 loops of 6mm mild steel round bar, on the vertical rear of the chassis for the rear, and on the crossmember for the front as I did not want to touch the steering bar holder (took that opportunity to empty the vacuum tank of oilly fluids before welding) the front welds are apart by about 15cm to spread the load, and the bar are about 18cm long to decrease shearing effect on the vaccum tank - haven't use any of them so far... except the rear one that serves also as ground clearance warning (on some tracks with strong left turns and heavy passenger)
S4SE 36/8198
nmauduit - Coveted Fifth Gear
