Tyre clearences.
PostPost by: arthur67 » Sun Jul 13, 2014 6:00 pm
Whilst fitting my solid driveshafts I noticed I had different amount of clearance between the tyre and the bottom of the spring platform.The nearside only has about 10mm while the offside has 20mm.it is a spyder chassis is this ok .Seems a bit odd.Any ideas whats going on.
Thanks Arthur
arthur67
First Gear
First Gear
PostPost by: robertverhey » Sun Jul 13, 2014 8:26 pm
Hmm start by swapping the wheels, to make sure your rims don't have different offsets
robertverhey
PostPost by: elansprint71 » Sun Jul 13, 2014 10:15 pm
Just drive it... :twisted:
PostPost by: robertverhey » Mon Jul 14, 2014 8:56 am
Having just re-mounted my s3 body on a spyder chassis, I was aware from various postings, (and, sure enough, when I did a trial fit) that there is approx 1 cm of side to side "wriggle room" at the rear of chassis (not at the front, which is held firmly between two turrets). Perhaps the person who fitted the spyder chassis was not aware of this, so your body is not quite centred at the rear. Anyway, still suggest you do the wheel swap above and at least remove different wheels as a potential cause. And check that body is centred on the chassis. Then if both of those check out, time to start looking at hubs and bearings as potential areas of discrepancy.
robertverhey
PostPost by: gus » Mon Jul 14, 2014 12:23 pm
the spring perches are not related to the body
Are the tires the same brand?
Tire width varies widely for the same contact patch
has one of the perches been hammered?
make sure the rims are straight and both torqued down
gus
PostPost by: arthur67 » Tue Jul 15, 2014 6:52 pm
Thanks for all the advice what a great forum.
Arthur
arthur67
First Gear
First Gear
