Engine mount to chassis bolts
PostPost by: bertavfc » Wed Jul 09, 2014 3:00 pm
Good afternoon, I'm just in the process of getting the last few bits together for the re-installation of the engine into my '69 +2. To my surprise the engine was only mounted to the chassis by one bolt per side so I'm looking for a couple of replacements, having measured the existing bolts they appear to be 11/32in (around 9mm) both these sizes seem near unobtainable, could anyone help me with a source for these?, many thanks in advance, Rob.
bertavfc
First Gear
First Gear
PostPost by: Europatc » Wed Jul 09, 2014 5:16 pm
Good evening Rob
if you are finding it that hard to source them try ringing Susan Miller or Paul Matty
just a thought :D
Stuart
Europatc
PostPost by: 69S4 » Wed Jul 09, 2014 6:27 pm
Its been a while since I last took those bolts out but I seem to remember that they're a fine thread as well - or is this another unofficial mod that a P.O. did?
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: StressCraxx » Wed Jul 09, 2014 7:05 pm
69S4 wrote:Its been a while since I last took those bolts out but I seem to remember that they're a fine thread as well - or is this another unofficial mod that a P.O. did?
I just did this last year with the newer motor mounts. The bolts are 7/16" UNF x 1" long. I use a full height nylock nut with flat washers on both sides.
StressCraxx
PostPost by: types26/36 » Wed Jul 09, 2014 7:53 pm
I seem to remember all ones I have worked on were 3/8 unf.
types26/36
PostPost by: RichardHawkins » Wed Jul 09, 2014 7:56 pm
Rob,
The bolts I removed were 3/8 UNF.
Richard Hawkins
RichardHawkins
PostPost by: CBUEB1771 » Wed Jul 09, 2014 8:36 pm
When all else fails there is the Service Parts List, XUFS0614, or 3/8-24 X 7/8 long bolts. The 7/8" length is not common and I have always used 1" long bolts.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: 69S4 » Thu Jul 10, 2014 6:11 am
StressCraxx wrote:I just did this last year with the newer motor mounts. The bolts are 7/16" UNF x 1" long. I use a full height nylock nut with flat washers on both sides.
Looks like a PO has used something else as the threads are finer than UNF. The guy I bought it from was a Navy helicopter technician and for years I found odd fastenings all over the car. Looks like this may be the last of them
Stuart Holding
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: bertavfc » Thu Jul 10, 2014 9:32 am
Many thanks for the replies, I had tried 7/16th but they were too big, I will go down the 3/8th route.
bertavfc
First Gear
First Gear
