Inertia seat belts and Spyder brackets
PostPost by: William2 » Wed Feb 19, 2014 5:34 pm
I have purchased a pair of Spyder inertia reel seat belt brackets for my S4 DHC and compatible seat belts. I also will be fitting a Tony Thompson roll bar. My question is whether any of you guys have fitted this combination to your Elans without any compatibility issues?
William2
PostPost by: l10tus » Wed Feb 19, 2014 9:54 pm
I have fitted a set (but not TT type).
Not sure have these fit, but I wanted to retain the original look as far as practically possible, by hiding the mechanisms behind the back of the cabin.
Found it a bit tight to hide them behind the curved carpeted back board though!
Angles are quite tight for the return to work effectively.
I used the original anchor point on the rear turrets, and obviously the same lower mounts.
Only worry is the slow return speed due to the angle and friction drag through the H/L slots in the B/ board.
All will be revealed once being used in Ernest!
Best of luck.
Post some pics when fitted please?
Phil.
Philip.
UK '72 Sprint DHC
l10tus
PostPost by: racy7 » Thu Feb 20, 2014 1:51 pm
I have fitted the spyder inertia reels and brackets to my S4 a couple of years ago and they work fine. As said the "return" is slow but they work and keep SWMBO very happy now!!
No compatability problems at all
racy7
First Gear
First Gear
PostPost by: Bud English » Thu Feb 20, 2014 6:23 pm
racy7 wrote:.... keep SWMBO very happy now!!
You are indeed a lucky man. :wink:
Bud
1970 +2S Fed 0053N
Bud English
