List of suggestions before re-mounting body to frame
Just got back from checking on progress at the body and paint shop for my Coupe, 36/5706. A bit behind schedule but my guy says he should have the car finished in about a month. I will bring the body home and fit it onto the chassis for assembly. Here is my request from members. I would like to put together a list of 10 or so things to do before fitting the body to chassis. Things that you have improved, modified, deleted, added, replaced, cursed at, want to do on the next one, wondered about, stared at or gave up on. I would like to avoid the "sounds like a great idea, wish I would have done that before I put the body on". My chassis is painted and on wheels. All suspension is on and mocked up. Engine is in (no cylinder head), as is the gearbox, driveline and starter. I am using a mechanical fuel pump. Brake line is fitted in the tunnel, emergency brake cable in attached in the rear and routed to the front. Fuel line is in with excess hanging out in the fuel tank end. This will give me some time to order or source parts.
Thanks in advance
Mike Summers
California
Thanks in advance
Mike Summers
California
- bluesbrother30
Mike,
I'll start the ball rolling:
Make sure you have the rear 'A' frame, inner mounting bolts fitted the right way around so that you can get them out with the body fitted. I have the bolt heads towards the rear.
Colin.
Colin.
bluesbrother30 wrote:Just got back from checking on progress at the body and paint shop for my Coupe, 36/5706. A bit behind schedule but my guy says he should have the car finished in about a month. I will bring the body home and fit it onto the chassis for assembly. Here is my request from members. I would like to put together a list of 10 or so things to do before fitting the body to chassis. Things that you have improved, modified, deleted, added, replaced, cursed at, want to do on the next one, wondered about, stared at or gave up on. I would like to avoid the "sounds like a great idea, wish I would have done that before I put the body on". My chassis is painted and on wheels. All suspension is on and mocked up. Engine is in (no cylinder head), as is the gearbox, driveline and starter. I am using a mechanical fuel pump. Brake line is fitted in the tunnel, emergency brake cable in attached in the rear and routed to the front. Fuel line is in with excess hanging out in the fuel tank end. This will give me some time to order or source parts.
Thanks in advance
Mike Summers
California
'68 S4 DHC
- fatboyoz
Hi Mike
Fatboyoz wrote
I personally would ensure that the bolt heads are on the inside of the A frame facing each other.
Regards Mick G
Regards Mick G
- MickG
Check the reverse light switch is adjusted and working - it is accessible with the body on but much easier when it's off.
S4 DHC
S4 DHC
- oldelanman
It is my understanding as well, that the bolt heads should be on the insides of the A frames, facing each other. That is how I have them on my cars.
From past experience, using the original matting or similar, over the backbone, is a no no. It retains moisture and that is not desireable on a steel chassis, no matter how protected.
Use a closed cell foam mat of the appropriate thickness, and if you trim it 3" above the 90 degree sill, it cannot be seen. Job done
Leslie
Leslie
- 512BB
512BB wrote:It is my understanding as well, that the bolt heads should be on the insides of the A frames, facing each other.
Yep....that's what Lotus said
Fill the diff, CHECK
Check the brake light switch, CHECK
Check the direction of the bolts on the rear wishbones..........yup both were backward, CHECK
Keep the ideas coming, thanks
ms
ms
- bluesbrother30
Invite some friends over to watch and help you line things up as you lower the body to the chassis. Extra eyeballs can help.
Are you volunteering?? Only 45 minutes away............
m
m
- bluesbrother30
Mick, I think I got it.........both bolts inserted from the "center" of the wishbone, threads facing front and back of the car. CHECK
m
Also gonna add a remote bleeder for the slave cylinder.
m
- bluesbrother30
bluesbrother30 wrote:Are you volunteering?? Only 45 minutes away............
m
Yep, if you're inviting...
K, pizza for lunch but limited beer........I want to make sure the body if facing the correct direction.
I have your number
m
I have your number
m
- bluesbrother30
