Fitting new body to an old chassis
PostPost by: Higs » Wed Dec 02, 2009 11:05 pm
I have just bought a replacement body for my Plus 2. What is the best way to fit it - should I weld up all the mounting holes and redrill and retap them? Or what?
Is there anything else I should worry about?
Higs
PostPost by: curly type 26 » Thu Dec 03, 2009 9:25 am
Hi Higs, that is exactly what i did some years ago worked out ok. just remember when body correctly settled on chassis if you have gaps between body & fixing points do not tighten to close gap make up alloy spacers to fill gap. Also if engine in chassis you will find front upright fixings impossable to drill i bought a 90 deg drill attachment from B&Q for about 19 squid comes with 3 wood bits & fits into your own drill worked out well. Have fun Curly :D
curly type 26
PostPost by: dusty » Thu Dec 03, 2009 10:13 am
Is this a "new" body or a "new secondhand" body?
If new where did you get it and what is the quality like?
Jon
dusty
PostPost by: peterako » Thu Dec 03, 2009 10:25 am
Hi Jon!
Hows the +2 Resto going?
Peter
peterako
PostPost by: dusty » Thu Dec 03, 2009 12:33 pm
peterako wrote:Hi Jon!
Peter
Sidelined for the moment whilst I finish the Seven.
Will try to organise a run around Lough Derg over the Christmas Hols if You are free.
Jon
dusty
PostPost by: peterako » Fri Dec 04, 2009 10:48 am
Don't have my car back yet. But am happy enough with progress.
I'm involved with a project this Christmas at Newgrange....on site :)
The timing of this work (or rather the proof of the work) is very dependent on weather (we need Sunrise) so I may be occuped with this.
But, would love to get to another run if I could!
Must drop down to see you and the family...and nearly as imprtantly....the 7 :D
Greetings to all,
Peter
peterako
PostPost by: Higs » Sun Dec 06, 2009 9:30 am
dusty wrote:Is this a "new" body or a "new secondhand" body?
Jon
Jon
The latter. Hopefully a better route than restoring mine. The body is just about ready for painting.
Higs
Users browsing this forum: elanman999 and 24 guests
