Rear suspension tower, chassis to body bolts
I think I've tracked down an annoying rattle to a loose bolt between the body and tower.
One side has a 5/16 UNF bolt and the other has a 3/8 UNF. Both seem to be in bobbins with 7/16 (untapped) holes.
What size should the bolts be?
Any problems expected if I drill/tap them out to the right size?
Thanks in advance.
Paddy
Thanks in advance.
Paddy
1963 Elan S1
paddy - Coveted Fifth Gear
Hi Paddy
They should be 7/16 UNF. It shouldn't be a problem drilling and retapping the 5/16 hole but you may only get a partially tapped hole in the other.
Look at the following site http://www.carbidedepot.com/formulas-tap-standard.htm
The minimum diameter of the 7/16 is just less than the major diameter of the 3/8 so you may be lucky.
Give it a go, don't forget - lots of oil on the tap!!
72 Sprint DHC
72 Sprint DHC
lotusfan - Third Gear
As per Mike's reply, the threads should be 7/16". Just to clarify, the chassis itself should have the tapped/threaded holes with plain bobbin holes. If there's 5/16" and a 3/8" in there, I would suspect a previous owner bodge, so go in with some caution.
Gerry
Gerry
- gerrym
