Tall Block twin cam in Spyder chassis
Am dry-fitting a tall block engine into my Sprint's Spyder chassis.
Seems like the old engine mountings will not line up with the holes in the chassis mounting points.
Does anyone know if that is the case, and the solution ?
Stuart.
Stuart.
- stuartgb100
elan-plus-f13/engine-sitting-too-high-t18036.html
The new mounts don't line up any better, I need to file fit the mounts as only 2 bolts line up at a time.
Thanks Gary,
I'll look through that link to see if there's a solution.
Just to be clear:
I'm swopping out a big valve standard block twincam from my Sprint for a tall block twincam.
I'm trying to reuse the perfectly good (virtually new, uprated TTR mounts) that I fitted to the Sprint.
The chassis is an early Spyder.
It "seems" there is a width issue between the early and later block.
Could that be right ?
Until I resolve that, I cannot check for bonnet clearance.
Stuart.
Just to be clear:
Stuart.
- stuartgb100
The solution is to file the engine mounts a bit with a 1/4 inch round file. Custom fit if you will...
The 1600 ford blocks are approx 1/4 inch wider at the engine mounts than the 1500/lotus blocks. The spacers between the engine mount and block need to be shortened
Dave
Elan 26R
Dave
Elan 26R
Dave Hughes
S2 26R
Elan DHC Sprint
S2 26R
Elan DHC Sprint
bigvalvehead - Third Gear
Gary / Dave, thanks.
Does it matter if the adjustment is made by slotting the holes on one side only,
or by halving the adjustment, and slotting both sides ?
Equally, can I just shorten the spacers in one go, or should I shorten the spacers and slot the opposte mount equally ?
Stuart.
Stuart.
- stuartgb100
