Sprucing up the frame
PostPost by: RotoFlexible » Tue Aug 14, 2007 1:52 am
I didn't really mean to take the body off the frame but everything else was apart and the upper front arms were trapped by the body. So far the frame has been cleaned and stripped. It's at a welder's shop for reinforcement, then I'll paint it. The frame was a replacement in about 1974 and has stood up very well. There is one small crack in an engine mount bracket and a slight twist in the left front tower, the result of a collision.
frame_dirty.JPG and
Moments after emerging from the body after 33-odd years. Diff and rack are still in place. The studs in the rear towers are roll bar mount points.
frame_cleaner.JPG and
After removing parts, degreasing and scraping, the frame is ready to go to the stripper's. Carpenter's level was used to check for twist. I also measured front-to-rear, diagonally, and across the fronts and backs of the front spindles.
frame_stripped.JPG and
Frame after chemical stripping. Bill Gavin and welder Bruce Stephens look it over.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: handi_andi » Sun Aug 19, 2007 9:19 pm
Looks like time for a good powder coat job....or have you got a reason for painting it instead?
Andy
handi_andi
PostPost by: RotoFlexible » Tue Aug 21, 2007 1:59 am
This shows some of the reinforcements. The modifications were mostly inspired by the photos and descriptions on this site.
Welds_XBrace.JPG and
Top view of the removable cross brace mount. The sheet metal extends a little too far back; I may need to grind it a bit.
Welds_RearTriangle.JPG and
Gussets in the rear triangle a la Tony Thompson.
Welds_RearTower.JPG and
Rear shock mount reinforcement.
Welds_EngMount.JPG and
Beefed-up engine mount. One mount had a tiny crack, the only crack in the frame.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: RotoFlexible » Tue Aug 21, 2007 2:08 am
handi_andi wrote:Looks like time for a good powder coat job....or have you got a reason for painting it instead?
Andy
The chief reason is cost - less than $100 for materials and disposable brushes vs. more than $1000 for powder coating. Also, with paint I can be sure of getting into all the corners and inside the spine, and it can be touched up if I chip it. Finally, I was tired of lugging it from place to place! I used KBS RustSeal, which is like POR-15 except that it comes in red oxide for a somewhat original look.
Painted_RearView.JPG and
Two coats on the topside.
Painting_Underside.JPG and
Putting the first coat on the underside.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: cabc26b » Tue Aug 21, 2007 6:06 pm
Have you tried to re-install your lotocones yet ? you might be in for a treat. I had to grind the flang , slot clut and use stainless AN cap screws to get it to work on the strteet car. The race car has the solid mounts and they were easier.
PostPost by: handi_andi » Tue Aug 21, 2007 7:44 pm
Might be a stupid question but are you sure Rustseal is a proper seal. I used something similar once and found that yes it stablised the rust but was in fact porous and without a suitable top coat of something else was not really worth the bother of using as the rust came back fairly quickly.
Andy
handi_andi
PostPost by: RotoFlexible » Wed Aug 22, 2007 1:06 pm
cabc26b wrote:Have you tried to re-install your lotocones yet ? you might be in for a treat. I had to grind the flang , slot clut and use stainless AN cap screws to get it to work on the strteet car. The race car has the solid mounts and they were easier.
It appears I will have to do the same :( .
handi_andi wrote:Might be a stupid question but are you sure Rustseal is a proper seal. I used something similar once and found that yes it stablised the rust but was in fact porous and without a suitable top coat of something else was not really worth the bother of using as the rust came back fairly quickly.
Not a stupid question at all. If the manufacturer's extravagant claims are even half true, the RustSeal should be fine for my purposes, which don't include a lot of use in bad weather. The stuff certainly doesn't look porous - it has a hard, glossy finish. It is UV sensitive but that's not an issue for the frame. We'll see how it holds up.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: RotoFlexible » Fri Sep 14, 2007 1:35 am
I finally re-installed the frame. Rather than taking the four-guys-two-sixpacks approach, I used the technique advocated by Brian Buckland of jacking the frame up into the body. I don't have the means of supporting the body as high as it needs to be, so I lifted it with a come-along and a sling, rolled the body underneath on two trolly jacks, lowered the body onto crates, and raised the frame to meet it.
One benefit of this approach is that it is a one-man job; the other is that I was able to take it nice and slow. There are vertical studs on the rear towers that have to engage with the roll bar - being able to precisely control the height and position of the frame made this fairly painless.
FrameInstall_1.JPG and
Starting position. The body has been lifted enough so the frame will clear.
FrameInstall_2.JPG and
Body lifted, frame rolled into place underneath. The next step is to lower the body onto the crates and remove the sling, then start jacking the frame.
FrameInstall_3.JPG and
Frame bolted into place, body back on the crates.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: jeff jackson » Mon Sep 17, 2007 5:20 pm
Have you got your diff in yet? Before bolting the body on?
Much, Much easier job to do, along with rear suspension etc... with the body off. ( Also, hopefully not teaching you to suck eggs either).
Jeff 72+2
jeff jackson
PostPost by: oldokie » Mon Sep 17, 2007 8:10 pm
I put everything on the frame first on a Plus 2; on Elans, you have to leave the carbs and exhaust for later.
Gene
oldokie
PostPost by: garyeanderson » Tue Sep 18, 2007 11:29 am
I guess if you have the room to completely build up the chassis its a good way to do it. If you are chalenged to find the room in your garage (or living room for that matter) for yor project Elan, then putting the body on the chassis as soon as you can isn't that big of a deal. On a S2 the only things that really have to be in place are the fuel line, emergency brake cable, the brake lines, front to rear (it just makes it a lot easier) and the top front control arms (this is a must) and saddle blanket if you use one.
Gary
garyeanderson
PostPost by: RotoFlexible » Tue Sep 18, 2007 3:19 pm
I took the minimal approach - brake lines, top control arms, saddle, fuel line, and steering rack. I neglected to install the handbrake cable but should have no problem snaking it through the empty spine. I was working with the frame at waist height on sawhorses (a real pleasure) but kept in mind that I had to transfer it to the floor by myself, so I wanted to keep the weight down. Also, I didn't have the diff finished when I was ready to install the frame. With the body and frame supported on crates, I had no trouble installing the diff and I expect no problems with the suspension. (My wife has her garage spot back so she's happy, which is another good reason to join the frame to the body sooner rather than later.)
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
