Chassis felt again!
PostPost by: tower of strength » Sun Oct 08, 2006 11:47 pm
Sorry about this guys,
I've trolled through the archive for hours and theres plenty of talk about the felt but no thicknesses, a couple of people have suggested neoprene, but no dimensions!!
Please help!!
tower of strength
PostPost by: elansprint71 » Mon Oct 09, 2006 7:21 am
Mark,
I used a (very cheap, about 4 quid) camping mat (the thing you sleep on in a tent!) from Argos, this is some sort of closed-cell substance, not neoprene but similar. It is about 5-6mm thick and is ideal for the job.
Pete.
PostPost by: john.p.clegg » Mon Oct 09, 2006 1:15 pm
Pete
Did you give it a short term test for petrol/oil etc....?
John :wink:
PostPost by: Lotus fan » Mon Oct 09, 2006 4:48 pm
Pete
No wonder you don't like us looking under your car at Sweaters 'cos it's probably BRIGHT PINK !!!! :shock: :mrgreen:
Ian F.
Lotus fan
PostPost by: tower of strength » Mon Oct 09, 2006 6:15 pm
elansprint71 wrote:Mark,
Pete.
Thanks Pete,
I've got a couple of those in the loft! guess I'll have to raid the camping kit!
thanks
p.s. mines pink and green :oops:
tower of strength
PostPost by: freddy22112211 » Tue Oct 10, 2006 8:39 pm
Buy some good rubber/plastic/foam, doesn't cost much. ~ 1 cm thick. Chuck the felt!
Gordon
freddy22112211
PostPost by: cliveyboy » Wed Oct 11, 2006 6:50 am
I am guessing the felt is fitted for two reasons. One is to cushion the fibre glass against the chassis to avoid point loading and cracking.
The other is to reduce vibration from the chassis to the body.
What ever you use should be able to resist fuel and oil, ideally not absorb water and be able to last the test of time.
Another point is that the material should be able to take the weight of the body and passengers etc with out compressing to the point where it is rock hard otherwise its pointless having it to reduce vibration from chassis to body.
Clive
1972 Elan Sprint FHC
cliveyboy
PostPost by: tower of strength » Tue Oct 17, 2006 8:05 pm
ok, I've got some foam rubber stuff thats petrol and water resistant, obviously it sits on the backbone, but does it also sit on the ledge that the body bolts to at the bottom of the chassis? Or does it just run down the sides!!???
tower of strength
PostPost by: types26/36 » Wed Oct 18, 2006 2:43 pm
tower of strength wrote: does it also sit on the ledge that the body bolts to at the bottom of the chassis? Or does it just run down the sides!!???Mark
The ones I have seen that were original only had the felt running down the sides and the felt was not on the ledge.
types26/36
PostPost by: tower of strength » Wed Oct 18, 2006 3:29 pm
thanks a lot Brian, the only pics I could find showed the spyder chassis, and that doesnt have a ledge around the bottom(only small mounting webs).
regards
tower of strength
PostPost by: elansprint71 » Thu Oct 19, 2006 4:48 pm
Here is a shot with the original felt on my old Sprint chassis- as always Mr Goodison speaks with non-bifurcated tongue!
Pete.
chass lft lge.JPG and
PostPost by: types26/36 » Thu Oct 19, 2006 5:13 pm
elansprint71 wrote:as always Mr Goodison speaks with non-bifurcated tongue!
Aww Pete :oops: ....now if I only knew what that ment :roll: ......and "Mr Goodison"!....what am I ..a doctor?
types26/36
PostPost by: tower of strength » Thu Oct 19, 2006 9:13 pm
thats excellent guys, thanks very much!!!
regards
tower of strength
