Galvanised Chassis
PostPost by: alan.barker » Mon Jun 15, 2020 3:41 pm
All this chat about galvanised Chassis reminds me of Ralphe Harris and the Aussie song about a Boomerang :lol: :lol: curved or not :roll:
The story still keeps coming back :P
PostPost by: gus » Tue Jun 16, 2020 3:35 am
alan.barker wrote:this is a Spyder Chassis with a bottom Pin problem too :oops:
Why keep posting the same one pic of a failed spyder chassis when lotus chassis were failing from the beginning?
gus
PostPost by: abstamaria » Tue Jun 16, 2020 12:29 pm
8BBE1ACE-FD71-40BD-8FB5-4C736681D5F6.jpeg and
Going through old files, I came across reprints from Lotus Remarque that I got in 1977, when I lived in the US and was still a member of Lotus Ltd. I came upon this article with some amusement.
abstamaria
PostPost by: tvacc » Tue Jun 16, 2020 1:05 pm
Remarks by an expert taken with respect. I did change the springs from side to side and the results were the same. I would suspect that if springs were the issue, the difference would move with the springs.
I did not check the front as it all seemed ok up there. My gut tells me that the difference in the rear was due to chassis flex but that and a few bucks will get you a coffee at Starbucks. Again, I still think it's a duck, but I could be wrong.
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham (Bought new), 05 Elise RD (Bought new),
99 Elise190, 05 Elise BLK (Bought nearly new), 2024 Emira, 2005 MiataSpeed Turbo
tvacc
PostPost by: rgh0 » Tue Jun 16, 2020 1:12 pm
tvacc wrote:Remarks by an expert taken with respect. I did change the springs from side to side and the results were the same. I would suspect that if springs were the issue, the difference would move with the springs.
Issue could be with front suspension and cross weights between LF and RR, and, RF and LR not just the rear springs themselves. When chasing suspension issues all 4 wheels interact
PostPost by: alan.barker » Tue Jun 16, 2020 2:45 pm
If a new front or body section is added as it cures can it twist/warp and effect the Chassis.
PostPost by: Donels » Wed Jun 17, 2020 4:36 pm
I really don’t understand the concerns about galvanising distortion. I have never seen any articles with before and after dimensions that prove it happens and to what extent. If we were talking about a half inch movement then there may be a concern but I suspect we are talking less than .100” if anything. That will probably upset Lewis Hamilton’s Merc but an Elan with a normal driver?
Any Residual stresses due to welding come out with time anyway causing distortion, it’s why castings for accurate applications are left outside for a few years before machining. I suspect galvanising just hastens the process.
Accept what you have and set the suspension up carefully. Let’s not even think about corrosion of none galvanised chassis allowing distortion.
Just an opinion!
Dave
Elan +2
Elise mk 1
PostPost by: alan.barker » Thu Jun 18, 2020 5:55 am
+1 Dave,
and it will never rust, well mine hasn't after 35 years.
For many the chat about twisted Chassis is just part of the banter at the Bar.
I don't think Spyder make adjustable rear "A" frames just to help out misleaded owners who have twisted Lotus Galvanised Chassis :oops: (nice little business Dell boy)
PostPost by: englishmaninwales » Sun Jun 28, 2020 10:32 am
+1 Dave and Alan.
I shim the rear de Dion tube ears to correct for welding distortion (on the tube) on my Caterham, accurately set up toe, camber and corner weights, but its life is spent on the limit on hillclimbs.
My Elan’s 35 year old rust free galvanised chassis, made on God knows whose jig, gets me to the supermarket and cruises around the beautiful North Wales roads perfectly.
Depends on what you use the car for.
Just my tuppence worth.
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
Previous
