lotus elan chassis replacement.
PostPost by: rgh0 » Mon Jul 11, 2016 11:30 am
My 73 plus 2 which I bought in 1982 had severe corrosion along the lower edge of the chassis backbone on each side where the lower 50 mm of the felt saddle covered it. This had occurred in its 7 or 8 years of life in the UK before it came to Australia
Unfortunately the felt had held water (and salt?) thrown up from the road into its lower edge leading to the corrosion. I guess there was not enough oil leakage from the engine or gear box to prevent it. The 5 speed rear gearbox seal is much better than the 4 speed so you get less oil inside the tunnel which runs though the seams to also prevent corrosion on the lower outside
PostPost by: andygrundy » Mon Jul 11, 2016 12:30 pm
Hi Rohan,
That confirms my fears about felt. I am pursuing the closed cell neoprene option.
Many thanks, Andy
andygrundy
New-tral
PostPost by: l10tus » Mon Jul 11, 2016 1:07 pm
Andy,
Take a look at the camping bed matts made from this type of foam.
They are generally green colour, about ?5.99.
Just the job!
Phil.
Philip.
UK '72 Sprint DHC
l10tus
PostPost by: andygrundy » Mon Jul 11, 2016 1:15 pm
Thanks for the tip Phil; I need to check if they soak up water though, although they wouldn't be much fun to sleep on if they did.
Regards, Andy
andygrundy
New-tral
PostPost by: 661 » Mon Jul 11, 2016 3:43 pm
Auto sound insulation firms usually have a huge selection
I've used these for my son's car:
http://www.deadening.co.uk/
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
PostPost by: andygrundy » Mon Jul 11, 2016 9:14 pm
Thanks Graeme, the Sound Deadening Shop certainly has a wide range of acoustic foam sheets.
I will check them out.
Regards, Andy
andygrundy
New-tral
PostPost by: patrics » Tue Jul 19, 2016 4:06 pm
I don't think acoustic foam is suitable as it is normally open cell - has to be to perform its acoustic function.
patrics
Previous
