What did you use to coat your chassis?
PostPost by: stugilmour » Sat Oct 05, 2013 2:24 pm
Sounds like a plan Dave. Plus 2 officially hibernating now at the Mother in Law's garage. We had a few snow flakes last week, :( If you are down over the winter we can take a bit of a look if needed.
Stu
Stu
1969 Plus 2 Federal LHD
PostPost by: RotoFlexible » Sat Oct 05, 2013 6:45 pm
I had my chassis stripped at a place that looked like a set for a horror movie, or maybe "Sweeny Todd." They did a good job. After I had some strengthening done, I painted it using products from KBS (http://www.kbs-coatings.com/?). This paint is probably a lot like POR-15; the primary reason I chose it was that it came in "Oxide Red," which turned out to be much brighter (closer to Spyder) than I thought. The car has been on the road for several years and the finish is holding up fine. I was able to paint inside the backbone section without too much difficulty.
frame_dirty.JPG and
Chassis sees the light of day after 30+ years.
frame_stripped.JPG and
Stripped chassis, at the welder's.
ChassisPainting.JPG and
Painting. Use gloves - once this stuff dries, it does not come off.
FrameInstall_1.JPG and
Mating the body to the chassis.
Andrew Bodge
'66 Elan S2 26/4869
RotoFlexible
PostPost by: Dave240 » Thu Oct 31, 2013 10:41 pm
So I'm getting ready to prepare the chassis for painting and I was wondering if my frame had already been modified already.
On the right hand side of the tunnel, there is a piece of metal riveted to the chassis. It starts at the bottom fold, then runs up about four inches up the side. I peeked inside the tunnel and it isn't concealing any damage, so I'm not sure why it would be there if it wasn't stock. However, the rivets look a little amateur.
See my (crappy) picture:
69 Elan +2 - Currently in as many pieces as physically possible
Dave240
PostPost by: Sea Ranch » Wed Aug 13, 2014 7:50 am
Dave, did you ever determine the origin of that riveted plate on your chassis?
And how's the build going?
Randy
Sea Ranch
Previous
