Galvanised frame - Paint or no paint?
I replaced my heavily corroded S3 chassis with a LR galvanized replacement. I sand blasted the new frame to remove any surplus or excess galvanising, hot soda wash and then powder coated. The powder coat has excellent adherence and I am very satisfied with the results. I have also made a sample 200 hour salt spray test to verify the powder coat durability on a galvanized surface. Despite the encouraging results it"s still dependent upon the powder coaters attention to detail.
- 65ginetta
alexblack13 wrote: It shone like a tanner.
Wots a tanner?
Like AussieJohn I used Hammerite when I replace the original chassis / subframe with a shiny galvanised one back in the 80's. It also fell off without any trouble - and continues to do so to the present day. Not one of my better decisions.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
- 69S4
Our "friend" from north of the border really meant,
"As bright as a new Sixpence"
A "Tanner" was the slang name for it, just as a "Bob" was a Shilling & a "Quid" was a pound
A sixpenny piece or bit was part of the pre-decimal GB currency & was worth half a Shiling (which was 12 Pennies) of which there were 20 to the Pound.
All so simple to understand really
I guess you already knew that Stuart, but maybe our friends across "the Pond" may have been scratching their heads a bit
Beware of the Illuminati
I left the other part of shining like a tanner out for obvious reasons John... Please don't explain that bit... Or you are on your own..
C U at the weekend..
Good luck and have fun everybody.
Al' .........
Al' .........
Alex Black.
Now Sprintless!!
Now Sprintless!!
65ginetta: that chassis assembly is looking beautiful! And thanks for the description of the chassis treatment. I take it, then, that you elected to use a light grey "metal colour" powder coating, no?
And thanks, John, for the clarification of the pre-decimal monetary units. Truthfully, I didn't know. Interesting how that number 12 was important to the imperial system.
Randy
Randy
alexblack13 wrote:I left the other part of shining like a tanner out for obvious reasons John... Please don't explain that bit... Or you are on your own..
Al' .........
Well you've lost me & my perverted mind there; obviously my Christian upbringing left me a bit short on the ways & sayings of the heathens
CU 2 M8
I painted mine using Hammerite special metals primer for galvanised steel, then used red garage door paint. Its a good, hard finish! Previously I did what someone else did and painted one with red "smooth" Hammerite and like his, it just "fell off" after about 3 months...! But my current one is lasting very well. It definitely looks better painted, IMHO.
Nigel Furness
Nigel Furness
- nigelrbfurness
Users browsing this forum: elanman999 and 10 guests
