"A" FRAME TOW BAR
PostPost by: sutol64 » Tue Sep 08, 2015 2:14 pm
I would like to tow my S1 about a thousand miles using an A frame tow bar. Should I go thru
the grill to attach ? , how wide is the grill opening ? or should I come up from under the car ?
anybody got one ? done this ? know dimensions ? TIA, sutol
sutol64
New-tral
PostPost by: jimj » Tue Sep 08, 2015 2:36 pm
I imagine you can guess the response; don`t. You`d have to fabricate some crank in the A frame to attach it underneath which is your only hope. You could use a dolly with the front wheels strapped down on it, but I believe that 40mph is the recommended top speed. We used one for a Westfield without a problem at speed. For a thousand miles you could buy a proper trailer and sell it afterwards or better still, drive the Elan there and fly back.
Jim
PostPost by: gherlt » Tue Sep 08, 2015 8:45 pm
How about renting a proper trailer ?
1964 S1 (in boxes)
1967 S3 DHC
1969 S4 FHC
gherlt
PostPost by: mbell » Tue Sep 08, 2015 10:04 pm
If it's the kind of a frame that you fasten/clamp to the suspension arms I wouldn't use it on an elan. The arms aren't strong enough.
As said better to get a trailer or other method.
PostPost by: denicholls2 » Wed Sep 09, 2015 12:59 pm
Presumably, the reason to consider such an approach is to save money over other options.
For a bit over $1,000, (OK, it was now several years ago, but the point is still valid), my Europa was delivered in enclosed freight from Port Angeles, Washington, to Massachusetts, a distance according to Google maps of 3,158 miles. It arrived looking and working as good as when loaded. (unfortunately its appearance did not improve in transit. :) )
You stand to do about $1,000 in damage by installing your towbar before all of the related possible mishaps of wheels-down towing. You might want to consider again which is really cheaper.
A four-wheel trailer capable of very safely managing an Elan is under $2000 brand spanking new and as noted has residual value if you choose not to keep it. I paid around $600 for a used one.
denicholls2
PostPost by: Elanconvert » Wed Sep 09, 2015 7:28 pm
well I actually have one of these A frames, cranked, which i have used frequently to tow my g15 to motorsport events, and all without a 'hitch'.......I sheathed the chains which wrap aroung the bottom wishbones [triumph] in rubber , and no damage.
however, I would hesitate to use it for more than 100m, although for no particular reason........just wouldn't feel comfortable
:D fred :D
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
Elanconvert
