Spyder Chassis Upper Removeable Brace
Hi, my Spyder Chassis was fitted with an upper removeable brace (fits across top chassis members beneath dashboard area).
I found that in order to remove the engine and gearbox (Zetec - MT75) that it had to be removed first. This was because the engine needs to tilt slightly upwards, then forwards, then drop gearbox, in order for it all to go in or out.
The crux of the operation seemed to be acessing the two screw heads that secure the removeable upper brace to the chassis. For those of you not familiar with the brace, it's very similar to the lower removeable Spyder chassis brace, and sits on conical mounts.
Has anyone got a smart way of removing the brace with the engine in situ.
Gerry
Gerry
- gerrym
Kevin, thanks for reply. Part of the reason for my "problem" is that the sump only has about 20mm clearance forward to the chassis front X-member. This would be insufficient to disengage gearbox from engine. Pretty tight all round. I can increase longitudinal room by tilting from of engine upwards, but to do this need to remove the x-brace beneath dashboard. This quickly becomes a circular problem. I know that when Spyder build their cars they drop the engine/gearbox into the chassis, then the removeable x-brace then the body.
Has anybody with a Zetec had cause to remove their engine.
Gerry
Gerry
- gerrym
Thanks all so far. Paddy, sump cannot be removed in situ as the front flange (of the sump) jams against the front X-member.
I take it that no one with a Spyder fitted Zetec/MT75 has in fact had cause to remove engine/gearbox with the removeable x-brace in position. Or else they have first removed the body!!!
I'll try extending the brace vertically (via welded thick walled tubes) so there's a more feasible spanner angle. A ratchetting ring spanner might just make it.
Good to check other items for serviceability as well. Fuel pipe connections where the emerge from the top of the tunnel?
(again, all built up with the body off)
Gerry
Gerry
- gerrym
