flexible brake lines
PostPost by: street » Sun Oct 27, 2024 8:06 am
My plus 2 was rebuilt 89/90. What thread do you think was the most probable at that time for the rear flexi's to hard lines as i need to replace.
SJ050J0005 - BRAKE HOSE SJ sports car lotus parts number, description does not have thread reference. As im In NZ, need to obviously get it right as most of the spares market here is American.
thanks
street
PostPost by: prezoom » Sun Oct 27, 2024 4:03 pm
On my 72 Plus2 all fittings are 3/8"-24.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: alan.barker » Sun Oct 27, 2024 9:08 pm
Hi Street,
As far as i know there is a garage in Auckland that works on Elans
PostPost by: RichardHawkins » Sun Oct 27, 2024 10:14 pm
Street,
3/8”x24 tpi (3/8”UNF) and 10mm x 1mm pitch are very similar, both are used in braking systems, I have seen these two systems mixed up. Measure carefully and use thread gauges to check the pitch.
Richard Hawkins
RichardHawkins
PostPost by: alan.barker » Mon Oct 28, 2024 6:05 am
I think the mix only comes as far as i know with the 16pb front Calipers on the later +2 cars.
On the connections yoy can sometimes see the "contiguous" circles for unified or maybe "m" for metric
PostPost by: smo17003 » Mon Oct 28, 2024 11:01 am
RichardHawkins wrote:Street,
Richard Hawkins
Richard is absolutely correct, I have found having a set of thread pitch gauges incredibly useful. Far better than trial and error when you have an unidentified fastener.
1967 S3 FHC
1968 S4 FHC
smo17003
PostPost by: alan.barker » Mon Oct 28, 2024 8:28 pm
If you want to go farther you can use thread parrellels or wires and measure effective dia with micrometer.
PostPost by: pharriso » Mon Oct 28, 2024 8:55 pm
Trying to measure pitch of a thread when they are close is not easy - why don't you buy a 3/8”x24 (unf) bolt & 10mm bolt & try them? You will have to bleed that brake afterwards, but not a biggy... .
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: alan.barker » Tue Oct 29, 2024 4:53 am
Hi Phil,
Good point but be careful i think one will go inside the other but is a sloppy fit (e.g. wrong).
PostPost by: 512BB » Tue Oct 29, 2024 8:48 am
'On the connections yoy can sometimes see the "contiguous" circles for unified or maybe "m" for metric'
I think you mean on the brass banjos Alan. I have seen the 2 circles markings on them but did not know what they meant. I have learnt something today, and there was I thinking I knew it all :lol:
Leslie
