New Dual Brake master Cylinder
PostPost by: umbyfer » Thu Jun 20, 2024 12:56 pm
Hello,
i need your help. On my Sprint Federal i have the Girling Dual Brake Master Cylinder LHD, bore 0.7" (17,8 mm).
It seems nobody sell a new reproduction. Tony Tompson and Classic Team lotus (Ex Paul matty) sell a similar type but for RHD only.
Thank you for any help.
Umberto
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
umbyfer
PostPost by: h20hamelan » Thu Jun 20, 2024 3:42 pm
I am sure I have used the Triumph Spitfire dual circuit, sorry I can not find the number.
Love your Mother
Earth
PostPost by: mbell » Thu Jun 20, 2024 8:27 pm
I've used a early spitfire on my +2, there also a shorter later one.
I suspect the brake line connections on the spitfire will be on the wrong side and tight to the inner arch. So might not fit.
PostPost by: rgh0 » Fri Jun 21, 2024 1:17 am
Theres a early Datsun 11/16 dual master cylinder with bottom outlets that will fit in a LHD or RHD car
edited as it fits in both LHD and RHD
PostPost by: umbyfer » Fri Jun 21, 2024 8:26 am
brake master cylinder federal.jpg and
I am considering to buy any used master cylinder removed from the car and put in a corner. If it is not too much damaged, it is possible to machine inside than to insert a cylinder in still in order to obtain the identical bore.
i am able to do it.
Thank you to everybody to have a look in the own cartons in garage.
Umberto Ferrari
Modena - Italy
Elite SII #1319
umbyfer
PostPost by: h20hamelan » Fri Jun 21, 2024 2:48 pm
There are a few others whom fit, they are all N American things like the 1969 Cortina GT Ford Corsair P/U.
If you are still stuck, I can turn on the old computer and find the file.
Love your Mother
Earth
PostPost by: umbyfer » Fri Jun 21, 2024 2:53 pm
h20hamelan wrote:There are a few others whom fit, they are all N American things like the 1969 Cortina GT Ford Corsair P/U.
i appreciate. thank you.
Umberto Ferrari
Modena - Italy
Elite SII #1319
umbyfer
PostPost by: 2cams70 » Sat Jun 22, 2024 1:15 am
Physically looks exactly the same as Australian specification Mk 1 Escort with tandem circuit front drum brakes. Not sure about internal bore size - would have to check. LHD or RHD should make no difference - or is this assumption incorrect?
The same part described as being for a Ford is likely to be a lot cheaper and more readily available than one described as being for a Lotus!
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: gav » Mon Jun 24, 2024 10:08 am
People like Classicar Automotive can restore master cylinders so if you have the original, they should be able to help.
gav
PostPost by: umbyfer » Mon Jun 24, 2024 1:03 pm
2cams70 wrote:Physically looks exactly the same as Australian specification Mk 1 Escort with tandem circuit front drum brakes. Not sure about internal bore size - would have to check. LHD or RHD should make no difference - or is this assumption incorrect?
LHD or RHD makes big difference on Elan! no space on left side for the pipes to connect to the cylinder. The master cylinder is very closed to the body.
Umberto Ferrari
Modena - Italy
Elite SII #1319
umbyfer
PostPost by: 2cams70 » Mon Jun 24, 2024 1:32 pm
I checked and Ford master cylinder is 0.75" bore so not suitable for Elan with 0.70" bore.
PostPost by: rideaway » Mon Jun 24, 2024 1:49 pm
Hello Umberto,
This winter I converted my Elan S4 from RHD to LHD and kept the RHD twin master cylinder. It's quite tight but it fits.
If that helps.
Best Regards
Stéphane
rideaway
