Brake Pedal Push Back
PostPost by: mark030358 » Sat Mar 30, 2024 10:39 am
Had a look at the archives and this subject has been discussed, but never answered apart from "swap the servo".
So one of the downsides today rre my run to the tuners was that my brake pedal started to "Push Back" up and go really hard, but the condition almost immediatley rectified itself. The condition came and went on my hours drive home but the brakes appeared to work just fine. If you have experienced the brake pedal pushing back it really is a weird feeling.
So my thoughts are that for the pedal to rise, fluid must be being pushed back from the servo to the master cylinder. From recollection it happens if I jut touch the brake, so as I release or gently maintain the brake pressure (I "think" maintain, need to try again) up comes the pedal. So the fluid lifting the pedal must be being moved by the servo and I am wondering if the control piston is sticking with the vacuum port on the "T" valve still open as per the "Brake Released" image attached, combined perhaps with a passing seal on the control piston. I cant see it being a passing seal on the output piston as not sure how this would move fluid back to the reservoir.
Anyway, one thing for sure the servo is coming off and I might just do all the caliper seals while I'm at it.
Screenshot 2024-03-30 at 10.20.52.png and
Screenshot 2024-03-30 at 10.22.05.png and
PostPost by: Simmo78 » Sat Mar 30, 2024 6:16 pm
Hi Mark, I’ll be following your exploits closely.
As like you over the past year I’ve had the same experience, although the brake pedal on my S4 would come back with such force it was impossible to then push it back down and unfortunately the brakes would be locked on and the car immobile. The only way to move the car / brake pedal was to crack off a bleed nipple.
I’ve spoken to many lotus people and brake caliper / servo re-manufacturers and nobody can give a definitive explanation.
My problems existed even after having had the servo refurbished by a reputable company.
I have recently rebuilt all the calipers with new seals and pistons, renewed the flexible hoses and have only just replaced the master cylinder. However one thing I did note was that whilst the master cylinder was recently overhauled by myself the small rubber seal at the end of the piston was a really tight fit / swollen and would often stick inside the white plastic cup resulting in the brake fluid not being able to return to the reservoir - hence replacing it with a new item.
Simmo78
First Gear
First Gear
PostPost by: Hawksfield » Sat Mar 30, 2024 7:58 pm
Hi its the control piston primary seal causing the lock up in girling servo. Renew seals
+2s130 1971
PostPost by: nmauduit » Sun Mar 31, 2024 10:04 am
I find this article from MG enthusiasts quite clear on servo operation, which in turn may help diagnosing the source of a malfunction
http://mgaguru.com/mgtech/brakes/bt201k.htm
S4SE 36/8198
PostPost by: Phil.C60 » Sun Mar 31, 2024 2:23 pm
It is, as John says, almost certainly a problem with the control piston getting stuck. The last issue I had like this was with a Rover P6 V8. Slightly different servo arrangement but the principle is the same: The piston bore and piston were rusty/corroded, probably due to water in the brake fluid making the piston a very tight fit in the bore. The brake fluid pressure from the pedal was sufficient to move it and operate the servo, but it wouldn't return on it's own so held the air admittance valve open causing the brakes to drag and occasionally lock on at traffic lights. Customer complaint was "occasional lack of power pulling away"! The servo had already been supposedly "Reconditioned" but there was no real access to the control piston bore so despite the rest of it looking lovely, it just didn't work. Replaced with NOS unit and the car was fine.
Phil.C60
PostPost by: mark030358 » Sun Mar 31, 2024 3:37 pm
Thanks to all posters. So we agree the control piston is the culprit…. :!:
As I said I the servo will be coming off and going for an overhaul. Preferably I’d like to sleeve both the bores, but not sure if the control piston bores can be done. Anyway I’ll be giving “PastParts” and the guys who advertise in Club Lotus a call on Tuesday to see who does what.
PostPost by: alan.barker » Sun Mar 31, 2024 6:45 pm
Mark,
Is there enough freeplay at the Master Cylinder and not the wrong length Pushrod.
PostPost by: mark030358 » Sun Mar 31, 2024 8:43 pm
alan.barker wrote:Mark,
Yes MC all OK and the brakes have been fine for +15 years, definatley the servo on this occasion. Given the service interval is 3 years, guess I have done quite well.
thanks
PostPost by: richardcox_lotus » Mon Apr 01, 2024 4:23 pm
Mark, in 29 years ownership I’ve experienced 3 servo failures, all showing the same symptoms as you describe.
It’s not been even length of time for them though. Lack of use makes the situation worse.
'72 Sprint
PostPost by: mark030358 » Tue May 28, 2024 4:59 pm
Well got my Servo back all nice and shiney..... and it does not work.
Same issue, pedal pushes back and also a couple of other strange things too.
At first the brake pedal would travel to the floor with the bleed nipple open and move what I would say was a standard amount of fluid. After a few bleed cycles the pedal wiould only travel maybe half a stoke and the amount of fluid moved was vastley reduced. Its not the master cylinder as I overhauled the original and same faults persisted, but to be sure I fitted a brand new MC and still the same.
I can only assume one of the pistons is stuck or sticking in the servo for no fluid to be pumped out into my jam (jelly) jar. Also I'm using 'Speed Bleeders" supplied by American cousins (they are excellent).
Anyway, anyone had these issues?
I will be sending the unit back under warranty, but what a ball ache.
PostPost by: reb53 » Wed May 29, 2024 6:44 am
I had these type issues several years ago.
I'd rebuilt my servo 30 years previously and figured this time it'd need the professionals to "do a proper job".
They had 2 attempts, and in the end, to their credit, refunded my money.
Which I used to buy a Lockheed replacement.
No problems since....
Ralph.
reb53
PostPost by: mark030358 » Mon Jul 15, 2024 1:05 pm
Hello all,
So got my rebuilt servo back again from "PastParts" who told me that they had replaced the piston with the ball bearing in and the unit tested fine. However I have exactly the same issue in as much as the brake pedal moves full stroke for maybe the first few dozen pumps, then progressivley gets harder to push. It basically only travels half a stroke then goes rock solid.
So I'm trying to unsderstand why this is. Anyone ??
thanks
PostPost by: alanr » Mon Jul 15, 2024 2:56 pm
Your problem is clearly not the Servo then is it.
How old is the brake master cylinder?
Also check the one-way valve in the metal line from the inlet manifold to the Servo is ok?
Alan.
Currently:-
1971 +2 S130/ 5speed Type 9.
PostPost by: Donels » Mon Jul 15, 2024 5:11 pm
The symptoms you describe suggest the servo is working and then stops working over a few pumps. As noted it doesn't appear to be the servo itself but it could be the vacuum supply to the servo. So check all vacuum pipes, check it is vacuum pipe that's fitted, look for collapsed pipes, leaks etc.
Elan +2
Elise mk 1
PostPost by: mark030358 » Mon Jul 15, 2024 5:17 pm
Hi Alan,
Master cylinder is new. I re-sealed/overhauled the original one while the servo was away for repair. When I experienced the issues after fitting the repaired servo it was the first thing I changed (for a brand new one). The one way valve in the servo is good, I tested it, I also left it attached to the "repaired" servo when I sent i9t back so it could be tested properly.
Why would the pedal just go hard mid-stroke, I feel if I knew why then this would help resolve my issue. My thoughts are....
WITH THE ENGINE OFF
With initially a lot of air in the system, the pedal moves the air and fluid from the servo/brake lines out via the bleed nipple. As the air content decreases so the pedal pressure required to move the fluid increases (I can actually feel this underfoot). Until there is a point where the pedal moves only to half stroke and feels like its hydraulically "locked". I am guessing that the bleed hole in the primary piston is being blocked by the servo push rod and the main piston is just not moving with the pressure that can be applied by the master cylinder (can this be right??). I can't work out why the servo pushrod would move without vacuum to block the bleed hole?
I must be missing something.... help has anyone experienced this?
Next
