Brake Fail Warning light
On my Super Safety, there is a micro switch on the floor, under the carpet which completes the circuit when the pedal pushes down on it and the light comes on, indicating that the brakes have failed.
I found this while siting at a stop light when I stretched my leg under the pedals and all of the sudden, it appeared my brakes "had failed"
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Elan45 wrote:On my Super Safety, there is a micro switch on the floor, under the carpet which completes the circuit when the pedal pushes down on it and the light comes on, indicating that the brakes have failed.
I'm sorry Roger, but this has made me laugh out loud
With the switch in that location wouldn't the first indication that your brakes have failed be "Sh!t, my brakes have failed!!!"
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
on my '68 s4se (Fed) the red brake fail light can be turned on by 2 means: un temporary manual switch under the dash to make sure that the bulb is operational, and a level switch on the brake master cylinder reservoir that goes on when the level is low.
Brake wise there is also a yellow light next to the red one that goes on when the handbrake (emergency brake... ) is on - quite useful so save these small pads
S4SE 36/8198
nmauduit - Coveted Fifth Gear
USA64 wrote:Yes, it warns of low brake fluid. I believe the sensor part which goes on top of the reservoir is available. It is the part it screws on to (which looks like a mushroom can) that is unobtainium.
Maybe...
http://www.minispares.com/product/Classic/GRK6009.aspx
There's a long thread that might help here:
viewtopic.php?f=42&t=19064
I was fairly new to this forum when I added my 2c to the thread, describing how I made my own fluid level sensor (being unable to find a Sovy switch). Although a hack it has been perfectly reliable and is still in use today. It's certainly better than nothing......
Nick
Nick
elanner - Fourth Gear
nmauduit wrote:on my '68 s4se (Fed) the red brake fail light can be turned on by 2 means: un temporary manual switch under the dash to make sure that the bulb is operational, and a level switch on the brake master cylinder reservoir that goes on when the level is low.
This is correct. As Nick has suggested, do a search on SOVY...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
john.p.clegg wrote:USA64 wrote:Yes, it warns of low brake fluid. I believe the sensor part which goes on top of the reservoir is available. It is the part it screws on to (which looks like a mushroom can) that is unobtainium.
Maybe...
John, do you know if it fits the Girling reservoir on our cars?
JonB - Coveted Fifth Gear
I don't know for sure but if you give them a call and discuss, it's surely worth a punt...
..or take a trip...
Unit 12&13
Cranbourne Industrial Estate
Cranbourne Rd
Potters Bar
Hertfordshire
EN6 3JN
..or take a trip...
Unit 12&13
Cranbourne Rd
Potters Bar
Hertfordshire
EN6 3JN
