Fitting new handbrake cable, is there a trick?
PostPost by: steve lyle » Sun May 07, 2023 6:10 pm
I figured I would fit it the reverse of how the old one came out. So starting at the front, and feeding the rear end of the cable through the threaded hole in the engine mount bracket.
But it won’t fit. It looks like I’d have to grind a lot of metal off the rear cable fitting, which I wont do without talking to Ken at DBE. Am I missing something?
D0C3987A-9039-43D4-AA97-7FA3BD5DA977.jpeg and
Steve Lyle
2007 BMW 335i Coupe
steve lyle
PostPost by: gjz30075 » Mon May 08, 2023 8:52 am
Is the nipple on the other end smaller? I'm guessing 'no' or you'd have it fed in already. Will be following
this.
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
PostPost by: steve lyle » Mon May 08, 2023 5:24 pm
gjz30075 wrote:Is the nipple on the other end smaller? I'm guessing 'no' or you'd have it fed in already. Will be following
this.
It’s a lot smaller, but you can’t install from that end because the outer sheath isn’t removable and won’t fit through the nut either.
I got a response from Ken. The bullet at the rear of the cable should be .315. The one he sent me is .375. So, bad cable.
Steve Lyle
2007 BMW 335i Coupe
steve lyle
PostPost by: vstibbard » Sun May 14, 2023 8:39 am
I’ve had that issue before, I’ve reduced the diameter on a pedestal grinder. Takes a couple of minutes.
Vaughan
PostPost by: baileyman » Sun May 14, 2023 11:39 am
vstibbard wrote:I’ve had that issue before, I’ve reduced the diameter on a pedestal grinder. Takes a couple of minutes.
Vaughan
Same. John
baileyman
cron
