master cylinder duo Girling
hello lotusians ,
On the Elan Sprint LHD I have a "duo" brake master cylinder, the one with the reservoir attached from below.
It is defective and has the reference G646 765 970 32 I find it in the parts book, page JD= Parts n° 2.
I can't find any! except the gasket kit but incomplete!
So can we swap good dealer addresses in Girling.
Thanks for sharing
geni
Thanks for sharing
geni
- geni
Hello Gérard,
first you should try to make sure what the exact type of your master cylinder is (you can then find out the bore from the internet without taking it out and measuring) - if unsure you should take it out, dismantle it, inspect it (making sure it's not corroded to a point making it unsafe for road use), and measure it to order the proper dimension rubber kit... For instance I believe SP2610 would be for 0.70" bore while the MS number discussed prior was 0.75" diameter...
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Hello,
I have dismantled my master cylinder, and it corresponds to 0.7" = 11/16 or 17.80m/m .
But where do you find the info to know the reference to the master cylinder number indicated?
I do not know all these details, knows why I ask this question.
geni
geni
- geni
Hello Gérard,
short of a photo showing the cast number, I just tried to guess from your previous post :
[quote="geni"
I can't find any!
geni[/quote]
then searched on the internet for Girling master cylinder numbers...
if you aready have the master cylinder out of the car, once checked for corrosion etc it should be relatively easy to order seals according to the dimension as measured (if stock no servo should be smaller than 0.75" and 64676597 does point to 0.70" bore so the kit you mentionned would fit )
[quote="geni"
I can't find any!
geni[/quote]
S4SE 36/8198
While researching my recently acquired dual master cylinder 64676597 031, I came across this
thread. I bought this thinking it would make a nice spare for my '72 Federal Sprint. I think
it also has a Cortina application.
Just as an fyi, this cylinder has two bore sizes. The one closest to the pushrod, working the front
brakes (in an Elan, anyway) has a .70 inches bore size and further down in the bore, working the rear
brakes, the bore is .660 inches. I realize this cylinder part number could also have a .75" bore
and was wondering if the .75" bore go all the way through?
Also, does anyone with a .70 64676597 cylinder have that bore size go all the way through?
Greg Z
45/0243K Sprint
45/7286 S3 SE DHC
45/0243K Sprint
45/7286 S3 SE DHC
gjz30075 - Coveted Fifth Gear
gjz30075 wrote:While researching my recently acquired dual master cylinder 64676597 031, I came across this
Hi, i have on my '71 federal Spritn the .70 64676597 041C. But it is mounted in the car and i cannot measuer. i have the new seal part bought in UK at powertrack. I can check the rubber seal diameter...
I need to buy one brake master cylinder as spare.
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
Modena - Italy
Elite SII #1319
- umbyfer
