Elan S4 master cylinder rebuild question
Hello,
I am looking for some insight into how to replace the following seal:
No idea how to get it off and on.
Many thanks in advance,
max
max
Lotus Elan S4
Alfa Romeo GTV6
Alfa Romeo GTV6
- madmaxsiegl
Slide a small screwdriver behind the seal, use the screwdriver to lever the seal over the end of the shaft.
Depending on how stiff the new seal is, you can stretch it over using your fingers, if not (as they say) assembly is the reverse of disassembly.
A bit of lube helps - as I assume you are ditching the old seal then you could use oil. When you refit the new seal, only use brake fluid.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
You can cut the old one off. The new one will stretch over the lumpy bits ok with a bit of finger work. Definitely lurbricate it but you are better using a caster oil based brake assembly lube than brake fluid. It is more slippery and doesn’t attract moisture like brake fluid which means you can store the assembled cylinder for some time without risk of corrosion
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Thanks so much for the responses.
I was suspecting that was a bit hesitant. Ready to move forward now.
cheers,
max
cheers,
max
Lotus Elan S4
Alfa Romeo GTV6
Alfa Romeo GTV6
- madmaxsiegl
Billmack wrote:Reminiscent of the birthing process
You sure must have some weird looking kids in that case!
- 2cams70
