Handbrake rods
I am wondering about the fasteners to attach the handbrake rods - currently, the outboard ends have a small UNF bolt and nut, the inboard end has a small clevis pin retained by a cotter pin.
Is any of this correct? I must say that the clevis pins are a lot less fiddly than the bolts.
art
- lightwait26
Don't lose the little bushes that go on those outboard end bolts
S4 DHC
S4 DHC
- oldelanman
If there is any looseness then replace the bolts/pins. All the holes in my original rods and T were tear-drops but I reamed them circular again (and made non-standard pins to fit) and the hand brake has been perfect for 40 years. All the grief about the handbrake is unnecessary if the clearances are small and well greased.
Meg
oldelanman wrote:Don't lose the little bushes that go on those outboard end bolts
+1. These are easy to lose/miss and made all the difference to my handbrake.
The Elan +2 parts manual at http://www.rdent.com has a breakdown for the Handbrake in the Brakes section (it's missing in the Elan section). This shows the bush - part No. 3.
It also shows the clevis/cotter at the inboard end of the rod and the bolt/nut at the caliper end.
I agree with Quart Meg Miles, if everything is tight the handbrake works fine. Well, 1960's fine. But it took me a number of battles to win the war.
Nick
elanner - Fourth Gear
Users browsing this forum: No registered users and 55 guests
