Elan S4 brake bleeding
PostPost by: Soonteo » Wed Nov 03, 2021 11:42 pm
I’m planning to bleed the brakes but, am not sure which is the correct brake fluid reservoir. Appreciate anyone’s advice. Attached photo shows two reservoirs in the engine bay.
Thank you
Tony Teo
080A89D2-F810-4267-859A-23AE8C48139E.jpeg and
Photo shows 2 reservoirs
Soonteo
New-tral
PostPost by: elanner » Wed Nov 03, 2021 11:57 pm
The large one is the brake reservoir. Confusingly, the reservoirs are the opposite way around from the pedals. I read somewhere: For right hand drive cars, at least, this allowed room for a larger brake reservoir which otherwise would foul the wing. For left hand drive cars this crossover was maintained. Go figure.
Nick
PostPost by: Soonteo » Thu Nov 04, 2021 2:30 am
Thanks Nick.
What then is the function of the smaller reservoir?
Best Rgds, Tony
Soonteo
New-tral
PostPost by: reb53 » Thu Nov 04, 2021 5:47 am
Clutch.
reb53
PostPost by: Soonteo » Thu Nov 04, 2021 5:34 pm
Appreciate all your input.
Now I can start bleeding my brakes.
Thank you, Tony
Soonteo
New-tral
PostPost by: geni » Fri Nov 05, 2021 12:03 pm
I would be interested to know the length of the push rod actuating the piston in the double circuit master cylinder (original) in engagement with the brake pedal on S4 Sprint.
geni
