Handbrake lever, Elan S3
PostPost by: John Larkin » Tue Feb 05, 2019 8:17 am
My handbrake lever handle was melted in a fire and is irreparable. The rest of the assembly is usable. Can anybody advise me where I can source a new or used handle or entire handbrake lever? I've tried the usual suppliers without luck.
I assume that the handbrake was sourced by Lotus from some other car manufacturer. Anybody know the source?
John Larkin.
1967 S3SE FHC, 1974 Rover P6B, 1949 Lancia Aprilia
John Larkin
PostPost by: geni » Tue Feb 05, 2019 10:52 am
je dispose d'un de rechange si cela vous int?resse faite moi photo de l'objet (voirparts list du catalogue) et vous confirme ensuite en message priv?
geni
PostPost by: geni » Tue Feb 05, 2019 10:55 am
I have this and if it may interest you, I am ready to sell it
geni
PostPost by: Bombay Racing Green » Tue Feb 05, 2019 11:03 am
Mk 1 Cortina John. Needs to be modified. https://rover.ebay.com/rover/0/0/0?mpre ... 2944575600
How?s it going?
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
Bombay Racing Green
PostPost by: John Larkin » Tue Feb 05, 2019 2:53 pm
geni wrote:I have this and if it may interest you, I am ready to sell it
Private message sent.
John Larkin
PostPost by: John Larkin » Tue Feb 05, 2019 2:58 pm
Bombay Racing Green wrote:Mk 1 Cortina John. Needs to be modified. https://rover.ebay.com/rover/0/0/0?mpre ... 2944575600
How?s it going?
Hi Peter,
I saw that Ebay advertisement this morning, but I thought it too expensive. I hunting around at the moment, and I may yet buy it if I have no luck elsewhere.
The body shell is ready for the paintshop. Collected the balanced prop shaft this morning. Chassis clean up and painting next. Expect to have chassis rolling again in April.
John.
John Larkin
PostPost by: billwill » Tue Feb 05, 2019 5:39 pm
If the metalwork of your handbrake is OK I expect you could make a new handle with that new rubber-putty stuff that sets like hard plastic.
I forgot its name for the moment.
Ah found it:
https://sugru.com/about
PostPost by: Elan45 » Tue Feb 05, 2019 6:07 pm
Because I too had a handbrake that had been a road fire and needed a replacement trigger or push-button, I traced that plastic part when I had my assembly apart. It would be a relatively easy part to make from 1/4inch plastic sheet. Do you need me to send you a copy of my tracing?
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
Elan45
PostPost by: John Larkin » Tue Feb 05, 2019 6:28 pm
Elan45 wrote:Because I too had a handbrake that had been a road fire and needed a replacement trigger or push-button, I traced that plastic part when I had my assembly apart. It would be a relatively easy part to make from 1/4inch plastic sheet. Do you need me to send you a copy of my tracing?
Roger, I would very much appreciate a copy of your tracing. My email is jfllarkin "at" gmail.com
John.
John Larkin
PostPost by: SENC » Wed Feb 06, 2019 4:27 am
John, see Steve's post about 6 down in this thread - you might see if he has any more.
lotus-suspension-f42/hand-brake-lever-t41970.html#p296754
Henry
69 Elan S4
65 Seven S2
PostPost by: John Larkin » Wed Feb 06, 2019 9:19 am
SENC wrote:John, see Steve's post about 6 down in this thread - you might see if he has any more.
Dear SENC,
Thanks for that link. I've emailed Steve.
John.
John Larkin
PostPost by: knockoffnut » Wed Feb 06, 2019 1:16 pm
I have a spare Elan handbrake handle assembly, and would be willing to trade for an original Seven S2 handbrake lever assembly...
1963 Unicorn
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
knockoffnut
PostPost by: geni » Wed Feb 06, 2019 1:50 pm
a quoi ressemble celui-ci ?
j'ai aussi la poign?e chrom? mais je ne sait pour le mod?le
geni
