Brake hose seals?
Yes. A copper washer, usually comes in the hose kit.
LaikaTheDog - Third Gear
For that angle of entry you should be using a banjo fitting if you are using the correct brake hoses.
- nigelrbfurness
PaulH wrote:I'm not sure if there should be a washer/seal between the brake hoses and the brake calipers. I can't see anything obvious in the parts list. Can anyone confirm please?
The flexi pipes and end fittings are shown in Section JA of the Parts Manual - under Bundy Pipes. The Banjo fittings and copper washers are shown.
S4 DHC
S4 DHC
- oldelanman
