Clevis pin size for brake & clutch push rods
Clevis pin is 5/16" dia x 7/16" long (underside of head to edge of split pin hole) ...... or approx 8mm x 12mm
That's for the original pushrod with fixed clevis, if an adjustable clevis is fitted or the pedal has been drilled oversize to overcome wear then yours may be different.
S4 DHC
S4 DHC
- oldelanman
oldelanman wrote:Clevis pin is 5/16" dia x 7/16" long (underside of head to edge of split pin hole) ...... or approx 8mm x 12mm
Awesome - thanks @oldelanman
1969 S4
1969 Europa S2
1990/1970 Ricciardi/Alfa
1969 Europa S2
- tjb0274
