Elan S3 brake upgrade
I want to upgrade the brake system of my Elan S3. I think the first is to put a brake servo and also the plus 2 brakes. Someone know if I feet the front brake disc of the plus 2, can I use the original bolt on wheels? Should i put a larger clutch pump?
Diego
Diego
- Dieschelan
Hi Diego,
Go ahead with your upgrade if you wish, but I have no problem with my S3SE with servo unit fitted.
I have locked all four wheels easily when frightened, and see no reason for any more brake power than that..
Eric in Burnley
S3SE DHC
Eric in Burnley
S3SE DHC
- ericbushby
Hi Diego,
Are you sure your standard brakes are operating as they should. If your rear calipers are rusted and frozen, your brakes will appear week. Standard S3 brakes in good condition are quite capable. Spend the money on stainless steel pistons.
Roger..
Roger..
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
The Elan at 700kg is well braked even by modern standards with the standard un-boosted system, disks and calipers and modern high friction coefficient pads and good quality brake fluid even in race situations.
You dont really need to go down the "big brake" approach in most real world usages including extreme race braking situations
If you upgrade the engine to 140-150 hp is not necessary to upgrade the brakes?
- Dieschelan
I upgraded the brakes on my S3 SE by removing the servo. No other changes. Added lightness, removed complexity, added feel.
Best
Best
1967 S3 SE DHC
1970 +2S (RIP - went out in a blaze of glory in 2001)
Stevie-Heathie - Third Gear
PNM Engineering have a new brake upgrade for the Elan. I am going to purchase it in a few weeks. They really have not marketed it yet. www.pnmengineering.com/
Send them an email. Tell them Tony from www.lotusowners.com sent you.
Looks like a really great kit. 4 pot...fits regular wheels. Should stop an Elan really quickly.
Tony V
Tony V
Tony Vaccaro
http://www.lotusowners.com
Drive Fast Take Chances
72 Elan Sprint, 93 Caterham (Bought new), 05 Elise RD (Bought new),
99 Elise190, 05 Elise BLK (Bought nearly new), 2024 Emira, 2005 MiataSpeed Turbo
tvacc - Fourth Gear
Dieschelan wrote:If you upgrade the engine to 140-150 hp is not necessary to upgrade the brakes?
No need - My 180hp Elan is fine with the standard brakes and no booster even on tracks with multiple heavy braking points down from high speed in a two minute lap. These braking loads are 10 times higher than anything you will experience in real life on the roads.
Even with the stock brake I never experienced fade on the street.
I upgraded to +2 / GT 6 front brakes, no booster, and spindles mostly to get the larger, stronger spindles to work with super sticky race slicks. I have had some brake fade on one track I go to but not anywhere else and never on the street.
Dave Bean (RIP) told me that frequent fluid changes to eliminate absorbed moisture in the system, was the key to good hi temperature brake performance. That would be the first thing to do if you are having fade issues.
BTW, BMW engineers said the highest brake temperatures they encountered was on long downhill runs even at moderate speeds.
Eric
64 S1 Hart
Eric
64 S1 Hart
ecamiel - Second Gear
If you want to get the best out of your standard Elan brakes then use DOT 5.1 fluid and change it yearly. The use a modern pad compound suited to your use helps as there is a huge selection and i have tried most. Finally a few tricks to maximise performance of standard setup can be done like, balance valve or selected pad coefficient front to rear , castellated pistons and insulated pad backing.
Yes long downhills certainly load brakes heavily. The Elan being light weight does not suffer as much in this situation as many other "fatter" cars like BMW and Porkers.
I agree with the advice to stick with the standard Elan brakes with our without booster, brake callipers serviced, master cylinder and quality pads, regular fluid changes and with booster similar braking to a modern car, without just more pressure required but awesome feel. If competing then bias is required using single master, otherwise a dual master with balance bar.
I noticed Rohan's comment about heavier cars, I've rallied and track day a 73 911S built to 2.8 RSR spec, I rallied competitively and won two prologs and now defunct due to major accident East Coast that ran in NSW rally outright, run its a Bathurst in and event which is a fast and hard on brakes circuit. The 911 weighs just over 1000kgs with cage etc, its running the race spec fluid, original spec aluminium front and std rear callipers and disks with pagid pads, the cars runs out to 8000rpm in every gear very quickly which equates to 150MPH in 5th. I've never experienced fade but regularly replace fluid, cooling ducts are fitted.
My experience is a well specified EOM and maintained disk all round set up with correctly chosen pads is more than capable of being used by the majority of punters.
V
V
- vstibbard
For the castellated Pistons i would think you just put 3 Blades in your Hacksaw at the same time and start cutting
- alan.barker
For castellated pistons a dremel or angle grinder with suitable disks will do what is needed. Be careful how deep you go to avoid cutting into the area covered by the seal when the piston is fully retracted.
Some of the Ferrodo pads i have used in the past had a bonded on backing, mainly for anti squeal properties I think but also effectvie heat insulation between the pad backing plate and the piston. Castellated pistons achieve the same effect of reducing heat transfer to the pistons and the Hawk pads i use these days dont have this style of backing.
