Brake servo ratio
PostPost by: arthur67 » Mon Sep 19, 2016 6:32 pm
Hi I bought a Lockheed type servo on E Bay ratio unknown a silly mistake to make.l think I may have the wrong ratio as initially on braking it seems ok then when you are coming to a stop it grabs on.
So is there any way to change the ratio now.?And what ratio am I supposed to have its a 1973 +2S.
Thanks for any help Arthur
arthur67
First Gear
First Gear
PostPost by: john.p.clegg » Mon Sep 19, 2016 8:23 pm
Arthur
You are supposed to have a 3:1 ratio,I've just upgraded mine to 4.25:1 and am pleased ( feel I'm getting older and my legs getting weaker ) you can tell by the little aluminium tag attached ( if it's still there ) if not it's a dis-assembly job and measure the two pistons ( slave and reaction ) and the air cylinder ( 7 or 8 inch )
Does it grab on or lock on,if the latter it's the reaction piston sticking...there is a spring mod to stop this
John :wink:
Back from Corfu refreshed...
PostPost by: arthur67 » Tue Sep 20, 2016 6:07 pm
Hi John it grabs on it doesn't lock on but it's a bit scary when you forget to brake gently so much so that I have blocked the vacuum pipe.
Regards Athur
arthur67
First Gear
First Gear
