Cleaning Brake Calipers
Anyone have thoughts (pro or con) on using a heated sonic cleaner to clean brake calipers? Solution is 50% water and 50% Simple Green. Obviously a thorough cleaning (using brake clean that is not harmful to rubber) to remove any traces of water would be required after the event.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto - Third Gear
I agree w/ you, just no petroleum based solvents. I use denatured alcohol for general cleaning and finish off w/ brake clean. I also make up a tool using a small radial brush from " Dremal" to clean inside the seal grooves. I use a piece of aluminum, perhaps 3/8 diam about 6 in long. Drill an 1/8 through hole near the end and a small tapped hole in the end to lock the brush into the 1/8 in hole. Use a circular motion to clean grooves. Works a treat.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
