Caliper Rebuild USA
PostPost by: fattogatto » Fri Mar 18, 2016 8:33 pm
Anyone have a reliable source for rebuilding/refurbishing/restoring the calipers from a baby elan in the US?
Thanks.
Charlie Warner
Fatto Gatto Racing
fattogatto
PostPost by: gus » Sat Mar 19, 2016 12:50 am
honestly buy some SS pistons and a seal kit, it is pretty easy
gus
PostPost by: SENC » Sat Mar 19, 2016 2:02 am
About to do the same on my new to me S4. Was planning to send the pistons off... Gus, where have yiu sourced SS pistons?
Henry
69 Elan S4
65 Seven S2
PostPost by: fattogatto » Sat Mar 19, 2016 2:15 am
RD has them.
Charlie Warner
Fatto Gatto Racing
fattogatto
PostPost by: mbell » Sat Mar 19, 2016 3:16 am
I got a quote from http://www.goldlinebrakes.com
I think a few people on here recommend them. I couldn't justify the price quoted radically with shipping, so I did it my self. The paint finish is no where as good as if done professionally but was significantly cheaper.
I got the pistons and seals from Sue Miller as significantly cheaper than US sources and I had a UK trip. Think I would have come out a head even with postage from the UK....
PostPost by: john1180 » Sat Mar 19, 2016 4:21 am
Try Eric at PMB performance. pmbperformance.com. They do a great job, complete disassembly, replate, and rebuild! John
john1180
PostPost by: john.p.clegg » Sat Mar 19, 2016 6:34 am
PostPost by: sveris » Sat Mar 19, 2016 5:12 pm
The owner of Vintage Imports - from the previous Ebay link -is a personal friend. You won't find a better source for old sports car parts on the Internet - period. He also has professional equipment to manufacture virtually any brake or hydraulic hose you might require.
Steve in Ohio
sveris
PostPost by: danielmo » Sat Mar 19, 2016 10:27 pm
You can get reasonably priced kits and stainless steel pistons from here: http://classicgarage.com/. The rears are the least expensive I've seen.
danielmo
PostPost by: ftsoft » Sun Mar 20, 2016 11:43 am
You can buy new calipers from Moss(Spitfire) for the fronts. The rears are more of a problem. I had mine rebuilt here in US locally by D&D Classics in Covington Ohio.
Frank
66 S2 26/5194
LP4711LA-B
ftsoft
PostPost by: cabc26b » Sun Mar 20, 2016 10:02 pm
+1 on goldline, used them to rebuild my early 911 calipers - reasonable and fast . I would buy the fronts from moss as others suggested and get the rears done -
George
PostPost by: SENC » Mon Mar 21, 2016 12:57 am
Those of you who have used goldline or PMB - did you spec or provide ss pistons, or go with alloy?
Any thoughts on goldline's newer finish vs the traditional zinc alloy used ny PMB?
Henry
69 Elan S4
65 Seven S2
PostPost by: fattogatto » Mon Mar 21, 2016 7:08 pm
Just called Goldline. Rather pricey at $90 per caliper to take apart, clean and rebuild. Pistons would be extra and then the zinc plating (if desired) would push $300 for all four. So, looking at $700+, plus shipping.
And, just got off the phone with PMB. $379 for the rears with parking brake, and $349 for the fronts. Includes plating and SS pistons though. Plus shipping.
Charlie Warner
Fatto Gatto Racing
fattogatto
PostPost by: collins_dan » Mon Mar 21, 2016 8:02 pm
I rebuilt mine with ss pistons from Ray and it was very easy. I did not paint the calipers, but was talking about it with a friend that has used this http://www.eastwood.com/eastwood-s-uret ... aints.html, which he said turned out very good. Just a thought. Dan
collins_dan
PostPost by: SENC » Mon Mar 21, 2016 9:35 pm
fattogatto wrote:Just called Goldline. Rather pricey at $90 per caliper to take apart, clean and rebuild. Pistons would be extra and then the zinc plating (if desired) would push $300 for all four. So, looking at $700+, plus shipping.
Thanks for sharing Charlie. I was thinking I could do it myself for $350-450 (including sending off for zinc plating), so $700-800 all-in doesn't sound too bad. Which are you going with and why?
Henry
69 Elan S4
65 Seven S2
Next
