Engine bay handbrake adjuster
Oh no tried to loosen this off and only broke it off,any idea how to overcome this,I take it the part of chassis it goes through is threaded,even if I got new handbrake cable I would have to get bit of adjuster out of that part,hindsight tells me I should have checked this before putting engine in ,never had a hindsight course?????
- el torro
Did you loosen off the jam nut before trying to adjust the fitting?
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
main reason I left mine alone......
just wondering.....tapping might be a bit awkward......drilling out won't be that easy either......
maybe use a longer adjuster from another h/brake cable [e.g. ford anglia?] and go through the mounting hole with nuts on both sides?
just a thought..
fred ..
just a thought..
fred ..
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
Because the outer cable finishes at the front of the car....
...and of course if the adjuster was at the rear it wouldn't be lubricated by the incontinence of the engine. I do feel for you though; try a bit of heat and lots of lube / WD40 / penetrating oil on the chassis mount, leave it for a day and then more heat and jam something you can turn into the seized bit - like a file tang or a screwdriver - with a bit of luck and a following wind it will come out without stripping the thread in the chassis.
Visit me on matthewvale.com
Matt Elan - Fourth Gear
