Plus 2 dual servo
I have in my plus 2 the dual system with 2 servos. There are original Girling. Outside there are rosty and bad aperience. What is the best choice to rebuild them or to buy the Loockheed type. Is there any difference between Girling and Loockheed?
If I buy the Loockheed I will have problems in the mounting because the Loockheed is larger?
- Dieschelan
In my experience the Lockheed is inferior to the original Girling so I would retain that if possible. The problem is that a lot of the Girling units are now too badly corroded internally to refurbish but you will only find that out after you have sent it away and whoever you use has dismantled it. Unless you are doing it yourself of course; I have seen rebuild kits available.
The Lockheed unit will fit fine, just not in the same place as originally. I have seen them stuck in a variety of places but mine is bolted to an adaptor plate bolted to the original Girling bracket.
If you do get a Lockheed, you may find this useful:
- Attachments
- RemoteServo.pdf
- (1.1 MiB) Downloaded 604 times
