Brake master cylinder replacement
Having made the decision to replace both clutch and brake master cylinders and researched how to do this i decided to remove the whole pedal box ,carbs etc, not an easy task but i thought it worth the effort. so i ordered replacement cylinders from Paul Matty. Fitting went without too many issues but took a whole day. The remaining braking system was also replaced including pipes, calipers and pads.
Then booked the car in for its first MOT after an 8 year rebuild and 400m before getting to the garage the brakes seized solid. three weeks later after a servo replacement and trying all possibilities the garage concluded the shaft out of the cylinder connecting to the brake pedal must be too long.
A phone call to Roy at Paul Matty resulted in the information that indeed the new cylinders output shaft is too long and the old cylinders shaft should be transferred, and documentation should have been included in the packaging and on the invoice, unfortunately in my case this was not done and confirmed by Roy.
Now the car is back via a low loader and i now have the task of re doing all of the work to fit the correct shaft, needless to say i'm not impressed. So advice to anyone about to undertake this task is to check the output shafts of any new cylinders match the ones removed and save yourself a lot of frustration.
- potleyu18
Sorry to hear that, something that is easy to miss if not in the know.
Have you considered modding the pedal box so you can remove the masters in situ?
A common mod and one I diff when I pulled and stripped my pedal box.
- mbell
a quick mod to be able to drive the car home is to undo the nuts holding master cylinder to pedal box.
Put in place temporary spacers between master cylinder/ pedal box and nip up the nuts.
- alan.barker
I had the same problem when I replaced my brake master cylinder. The front brakes kept locking up. Until I realized I had the wrong length rod, my solution was to use a wrench to crack open the fitting on the master cylinder for the brake line, relieve some pressure and then drive away. The minute you use the brakes a couple of times the pressure builds back up and the brakes lock again.
The reason for this is there is a valve that is at the end of the master cylinder that releases the pressure after a stroke of the piston. The longer rod does not let the piston completely release and the pressure increases until the brake pads engage on their own. The shorter rod (3 1/2" for my S1) made all the difference in the world.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Steve,
Here's a pic of my mod to the top of the pedal box on my early +2. You don't have to use quite as many srcews as I have done. I just got carried away.
It does make replacement of the M/C's much easier.
- elanman999
With that many screws I'm sure it would take longer.......
don't put Loctite on all those screw threads, it will take even longer
- alan.barker
Users browsing this forum: Baggy2, mark030358 and 8 guests
