Play in Handbrake Caliper Pivots
PostPost by: david.g.chapman » Mon Apr 13, 2015 2:10 pm
My +2 is through the MOT again :D but I had an advisory on play in the handbrake calipers. The handbrake itself works OK.
If you grab the calipers you can rock them a good few mm on their pivots, and there is play between the calipers and the main rear brake caliper body. A steel shaft is set into the main caliper to provide the pivot. Can this shaft be removed?
If not, I could fit some shims each side of each handbrake caliper to eliminate the rocking, but I would prefer to remove the shaft and calipers, and enlarge the shaft/bush the calipers.
This sort of play is responsible for a lot of the rattling you can get when going over bumps - especially with the windows down!
Dave Chapman.
david.g.chapman
PostPost by: jono » Mon Apr 13, 2015 4:40 pm
Classic car Automotive refurbished my calipers and they re bushed the handbrake pivots and fitted new pins so it's all doable :D
PostPost by: types26/36 » Mon Apr 13, 2015 5:00 pm
This thread contains some information on the the pivots.
lotus-suspension-f42/hand-brake-pads-t17819.html
types26/36
PostPost by: david.g.chapman » Mon Apr 13, 2015 5:51 pm
Thanks to you both! I'm spoilt for choice on which way to go.
When I do it I will try and remove the rod myself - otherwise it's off to ClassicCar Automotive.
Dave.
david.g.chapman
